Anyone have experience supercharging a slant six? #3145318
05/18/23 12:46 PM
05/18/23 12:46 PM
delivering your oil
nutso suave Online content OP
nutso suave  Online Content OP
delivering your oil
Maybe this isn't the correct forum, if so my apologies. I recently saw that there are supercharger kits available for slant sixes from TorqStorm. Does anyone have any experience with these? The information given indicates that with EFI or a blow through carb it can show 50% power increases, along with several other modifications to the fuel system (electric pump) and modified ignition timing. Getting a V8 would probably be the easier choice but these little engines are cool and to be able to make 200=250 hp with a slant would be unique.
Does the bottom end have the strength to handle that additional boost pressure and fuel? I have read that there isn't really room to bore out the cylinders, which limits displacement but they are really heavy and strong because they were originally designed to be made from aluminum.
Has anyone seen these in person?
Re: Anyone have experience supercharging a slant six? [Re: nutso suave] #3145423
05/18/23 09:10 PM
05/18/23 09:10 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
A buddy of mine has a 68 Dart with a Torqstorm and efi he just put together. He had it running for 3 weeks, then drove from Virginia to Missouri to race, won 2 rsces, and drove home with no issues. Car ran 13:20s.
He is on www.slantsix.org as Dart270. He's documented it well.
The Slant bottom end really doesn't need much. They're pretty tough to start with. You can easily bore them +.100", I know of some that have gone +.190" after sonic checking.
The bad part is the head sucks. But with a blower that isn't such a big issue.
Re: Anyone have experience supercharging a slant six? [Re: slantzilla] #3145453
05/18/23 11:24 PM
05/18/23 11:24 PM
delivering your oil
delivering your oil
Thanks for the link, I’ll check it out. I looked around on the internet for build info but I missed that thread.
It seems like having EFI, electronic timing, fuel pressure regulation, and boost would really make the car drive better overall, even if you weren’t racing or hot rodding around.
Re: Anyone have experience supercharging a slant six? [Re: nutso suave] #3145454
05/18/23 11:31 PM
05/18/23 11:31 PM
Canada
Kam*Kuda Offline
Kam*Kuda  Offline
Canada
We have a local guy with a slant six and a procharger in a dart
It’s a really cool set up and certainly an attention grabber car shows
He is local if you have any questions, I can see if I can chat with him
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: Anyone have experience supercharging a slant six? [Re: nutso suave] #3145480
05/19/23 02:11 AM
05/19/23 02:11 AM
Someone, maybe on here, did that years ago, I think it made around 230 HP. same as a stock poly 318 two barrel motor makes shruggy work
Not my cup of progress tsk work whistling
Re: Anyone have experience supercharging a slant six? [Re: Cab_Burge] #3145503
05/19/23 08:28 AM
05/19/23 08:28 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Dave Evans in Minnesota built one with a 4-71 in the late 90s. It dyno'd at 425 on pump gas. Another guy in Minnesota now has it in a rat rod.
Steve Nitti, also from Minnesota has a gorgeous 72 Duster with a Procharger on it. It went 10.57@126 at Mokan last month. Car weighs 3200 w/driver.
Re: Anyone have experience supercharging a slant six? [Re: slantzilla] #3145534
05/19/23 10:49 AM
05/19/23 10:49 AM
delivering your oil
delivering your oil
I was reading 'watsonwerks' build and test thread on SlantSix Forum, still reading the one you mentioned. It sounds like 4-6 psi of boost really warms up the engine....14-15 pounds would theoretically double the horsepower if the exhaust, fuel, were set up to match. That's a lot of power from a slant! I have been enjoying reading up on the threads there..I'm learning a lot, plenty of good info. Thanks again!
Re: Anyone have experience supercharging a slant six? [Re: nutso suave] #3145536
05/19/23 11:15 AM
05/19/23 11:15 AM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Anyone have experience supercharging a slant six? [Re: bigdad] #3145565
05/19/23 12:55 PM
05/19/23 12:55 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
That's Wes Alumbaugh's old Valiant. It was a gorgeous car, but $36K??????
Re: Anyone have experience supercharging a slant six? [Re: slantzilla] #3145574
05/19/23 01:33 PM
05/19/23 01:33 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
Building your own kit is always an option. Aussie Speed sells manifolds now for the /6. An Eaton M90 would be perfect on a /6 and can be had for $150 pulled off of 3800 series GM motors. Aussie Speed manifold is about $750 I think.
https://www.aussiespeedshop.com/product/slant-6-chrysler-supercharger-manifold-as0042/
Re: Anyone have experience supercharging a slant six? [Re: nutso suave] #3145819
05/20/23 03:17 PM
05/20/23 03:17 PM
New York
polyspheric Offline
polyspheric  Offline
New York
The block begins to fail above 400 hp.
If that's enough, go for it.
Boffin Emeritus
Re: Anyone have experience supercharging a slant six? [Re: polyspheric] #3145873
05/20/23 06:32 PM
05/20/23 06:32 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
That's total crap.
Re: Anyone have experience supercharging a slant six? [Re: slantzilla] #3145874
05/20/23 06:39 PM
05/20/23 06:39 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
That's total crap.
Please elaborate.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Anyone have experience supercharging a slant six? [Re: slantzilla] #3145895
05/20/23 08:06 PM
05/20/23 08:06 PM
How many main caps do they come with?
Isn't it 4 or 5? Not 7, correct work
I knew a kid in high school who had a aluminum four barrel slant six four barrel motor with a 4 speed manual tranny in a 1960-1961 Valient or what ever the first year compacts were called back then. It ran oaky but I don't think it was halfway fast shruggy confused
Re: Anyone have experience supercharging a slant six? [Re: Cab_Burge] #3145898
05/20/23 08:51 PM
05/20/23 08:51 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Slants have 4 mains. The only ones I know of that even broke a crank either hydrauliced a cylinder spraying on alcohol, or trying to spray a turbo motor.
Mike Jeffrey was making well over 400 on spray and never even nicked a main bearing.
We have turbo guys making north of 500 and the only thing they've eaten were pistons.
The motor I just took out of my car has the light cast crank in it with stock rods. I wasn't making a lot of power (250ish) but turned 6300 regularly. I had 0 bottom end issues.
People have told me for 25 years Slants can't live with only 4 mains. I have never hurt a bearing even when I was spraying. I was only making 375 though.......
Re: Anyone have experience supercharging a slant six? [Re: Kam*Kuda] #3145913
05/20/23 10:17 PM
05/20/23 10:17 PM
Canada
Kam*Kuda Offline
Kam*Kuda  Offline
Canada
I just saw him and took a couple pictures for you. I spoke to him and he bought the car this way and didn’t know lots of info
1654.5 Mustang
1955 Land Rover
Re: Anyone have experience supercharging a slant six? [Re: slantzilla] #3145920
05/20/23 11:04 PM
05/20/23 11:04 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Because you say so?
Love your use of language...
Boffin Emeritus
Re: Anyone have experience supercharging a slant six? [Re: Cab_Burge] #3145923
05/20/23 11:10 PM
05/20/23 11:10 PM
New York
polyspheric Offline
polyspheric  Offline
New York
IIRC none of the Hyper-Pack engines were aluminum blocks.
The 170" was 148 hp, 225" 195.
Boffin Emeritus
Re: Anyone have experience supercharging a slant six? [Re: polyspheric] #3145951
05/21/23 07:12 AM
05/21/23 07:12 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
You do realize that other then the 7 170ci NASCAR Compact Valiants there were no Hyper-Pak motors, right? The H-P program was an over the counter kit Chrysler had to make available so the Valiants were legal.
Re: Anyone have experience supercharging a slant six? [Re: slantzilla] #3145973
05/21/23 10:52 AM
05/21/23 10:52 AM
New York
polyspheric Offline
polyspheric  Offline
New York
This is such fun
I didn't provide every single known fact, therefore my comment is wrong? Take 5 minutes, tell me everything you know.
Boffin Emeritus
