Re: Anyone have experience supercharging a slant six?
[Re: nutso suave]
#3145423
05/18/23 09:10 PM
05/18/23 09:10 PM
Posts: 20,202 Park Forest, IL
slantzilla
Park Forest, IL
A buddy of mine has a 68 Dart with a Torqstorm and efi he just put together. He had it running for 3 weeks, then drove from Virginia to Missouri to race, won 2 rsces, and drove home with no issues. Car ran 13:20s. He is on www.slantsix.org as Dart270. He's documented it well. The Slant bottom end really doesn't need much. They're pretty tough to start with. You can easily bore them +.100", I know of some that have gone +.190" after sonic checking. The bad part is the head sucks. But with a blower that isn't such a big issue.
[Re: nutso suave]
#3145454
05/18/23 11:31 PM
05/18/23 11:31 PM
Posts: 4,244 Canada
Kam*Kuda
Canada
We have a local guy with a slant six and a procharger in a dart
It’s a really cool set up and certainly an attention grabber car shows
He is local if you have any questions, I can see if I can chat with him
1970 Barracuda Convertible 1968 Satellite Street Strip car 1654.5 Mustang 1955 Land Rover
[Re: Cab_Burge]
#3145503
05/19/23 08:28 AM
05/19/23 08:28 AM
slantzilla
Park Forest, IL
Dave Evans in Minnesota built one with a 4-71 in the late 90s. It dyno'd at 425 on pump gas. Another guy in Minnesota now has it in a rat rod.
Steve Nitti, also from Minnesota has a gorgeous 72 Duster with a Procharger on it. It went 10.57@126 at Mokan last month. Car weighs 3200 w/driver.
[Re: bigdad]
#3145565
05/19/23 12:55 PM
05/19/23 12:55 PM
slantzilla
Park Forest, IL
That's Wes Alumbaugh's old Valiant. It was a gorgeous car, but $36K??????
[Re: nutso suave]
#3145819
05/20/23 03:17 PM
05/20/23 03:17 PM
Posts: 4,210 New York
polyspheric
New York
The block begins to fail above 400 hp. If that's enough, go for it.
Boffin Emeritus
[Re: polyspheric]
#3145873
05/20/23 06:32 PM
05/20/23 06:32 PM
slantzilla
Park Forest, IL
The block begins to fail above 400 hp. If that's enough, go for it. That's total crap.
[Re: slantzilla]
#3145874
05/20/23 06:39 PM
05/20/23 06:39 PM
Posts: 12,591 Great Neck,LI,new york
hemi-itis
The block begins to fail above 400 hp. If that's enough, go for it. That's total crap. Please elaborate.
[Re: slantzilla]
#3145895
05/20/23 08:06 PM
05/20/23 08:06 PM
Posts: 43,269 Bend,OR USA
Cab_Burge
How many main caps do they come with? Isn't it 4 or 5? Not 7, correct I knew a kid in high school who had a aluminum four barrel slant six four barrel motor with a 4 speed manual tranny in a 1960-1961 Valient or what ever the first year compacts were called back then. It ran oaky but I don't think it was halfway fast
[Re: Cab_Burge]
#3145898
05/20/23 08:51 PM
05/20/23 08:51 PM
slantzilla
Park Forest, IL
Slants have 4 mains. The only ones I know of that even broke a crank either hydrauliced a cylinder spraying on alcohol, or trying to spray a turbo motor.
Mike Jeffrey was making well over 400 on spray and never even nicked a main bearing.
We have turbo guys making north of 500 and the only thing they've eaten were pistons.
The motor I just took out of my car has the light cast crank in it with stock rods. I wasn't making a lot of power (250ish) but turned 6300 regularly. I had 0 bottom end issues.
People have told me for 25 years Slants can't live with only 4 mains. I have never hurt a bearing even when I was spraying. I was only making 375 though.......
[Re: Kam*Kuda]
#3145913
05/20/23 10:17 PM
05/20/23 10:17 PM
Posts: 4,244 Canada
Kam*Kuda
Canada
He is local if you have any questions, I can see if I can chat with him I just saw him and took a couple pictures for you. I spoke to him and he bought the car this way and didn’t know lots of info
[Re: slantzilla]
#3145920
05/20/23 11:04 PM
05/20/23 11:04 PM
polyspheric
New York
Because you say so?
Love your use of language...
Boffin Emeritus
[Re: Cab_Burge]
#3145923
05/20/23 11:10 PM
05/20/23 11:10 PM
polyspheric
New York
IIRC none of the Hyper-Pack engines were aluminum blocks. The 170" was 148 hp, 225" 195.
Boffin Emeritus
[Re: polyspheric]
#3145951
05/21/23 07:12 AM
05/21/23 07:12 AM
slantzilla
Park Forest, IL
IIRC none of the Hyper-Pack engines were aluminum blocks. The 170" was 148 hp, 225" 195. You do realize that other then the 7 170ci NASCAR Compact Valiants there were no Hyper-Pak motors, right? The H-P program was an over the counter kit Chrysler had to make available so the Valiants were legal.
[Re: slantzilla]
#3145973
05/21/23 10:52 AM
05/21/23 10:52 AM
polyspheric
New York
This is such fun
I didn't provide every single known fact, therefore my comment is wrong? Take 5 minutes, tell me everything you know.
Boffin Emeritus
