Re: BBM Dry Sump Q's
[Re: AndyF]
#3144584
05/14/23 05:06 PM
05/14/23 05:06 PM
Posts: 19,361 Las Vegas
Al_Alguire
Las Vegas
IMO not convinced it is of any benefit especially in a Mopar. The issue is getting the oil back in the engine. I have done it on a few engines over the years and if there is a benefit its minor over a GOOD wet sump system. MOst guys cheap out on wet sump stuff with "low tech" pans that dont control the oil well and then follow it up with a glorified stock style pump.
[Re: Dragula]
#3144892
05/16/23 06:48 AM
05/16/23 06:48 AM
Posts: 4,647 aotearoa
rebel
aotearoa
Missel, that is the one I am thinking of....Do they still make those, and does it sit past the front of the timing cover at all? I think Indy sell them now. But as per pic, they do hang out front a bit.
[Re: Dragula]
#3144963
05/16/23 12:00 PM
05/16/23 12:00 PM
Posts: 46 Finland
LUMI
Finland
I have never really been interested in stepping up to one, but I wonder if would better keep my Hemi alive and from starving 7-8 bearings....
My first question is, do the make a pump for BBM that does not use a belt drive but runs off the drivers side like a KB pump?
Is the scavenging better with a dry sump & tiny pan?
Who is using one for street & strip? autoverdi here in europe has one https://www.autoverdi.com/pump-models#section-80
[Re: Dragula]
#3144965
05/16/23 12:09 PM
05/16/23 12:09 PM
Posts: 2,105 Byron, NY
W.I.N. Racing
Byron, NY
Its become very common in the Blown Alch/Nitro ranks RCD Oil PumpSystem 1Are two examples I would speculate is is more for oil retention during a "Pan failure" than a performance gain.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
