E-Body Brake Booster/Master Cylinder Replacement #3144164
05/12/23 12:58 PM
05/12/23 12:58 PM
Addison Twp, Mi.
RobG Offline OP
RobG  Offline OP
Addison Twp, Mi.
My brakes system is soft. I want to replace these items, but on a budget. I am not worries about number matching parts - I like to drive my car all the time.
What would you recommend as a good replacement? Should I just order rebuilt components from my local auto parts store or is there a good specialty shop that won't break the bank?
I am not rich...but I get off my ass everyday to make sure I am not broke!
Can we get the Mexican cartels to help us with our supply chain issues? They don't seem to have any trouble getting stuff from one place to another.
Re: E-Body Brake Booster/Master Cylinder Replacement [Re: RobG] #3144214
05/12/23 04:22 PM
05/12/23 04:22 PM
ILL
Greentween Offline
Greentween  Offline
ILL
Maybe switch to 2 bolt aluminum master cyl at same time?
Cardone 54-73870
Dorman M99294
But you will need to mention if you have drum or disk setup now.
Re: E-Body Brake Booster/Master Cylinder Replacement [Re: Greentween] #3144219
05/12/23 04:46 PM
05/12/23 04:46 PM
BDW Offline
BDW  Offline
When I upgraded to the factory 11.75 discs, I bought the rotors and calipers from Advanced Auto.
They have lifetime warranty on the calipers, that was 15yrs ago, they replaced 1 of the calipers 7 years ago, no issue.
RockAuto is nice, but for stuff like this, I'd go local.
Re: E-Body Brake Booster/Master Cylinder Replacement [Re: Greentween] #3144268
05/12/23 09:35 PM
05/12/23 09:35 PM
Addison Twp, Mi.
RobG Offline OP
RobG  Offline OP
Addison Twp, Mi.
Disc/Drum
Re: E-Body Brake Booster/Master Cylinder Replacement [Re: RobG] #3144276
05/12/23 10:19 PM
05/12/23 10:19 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
You don't say what exactly is wrong with them, or what you have, maybe you should start there so that people can give educated advice.
Re: E-Body Brake Booster/Master Cylinder Replacement [Re: 71birdJ68] #3144297
05/13/23 03:11 AM
05/13/23 03:11 AM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
Start with old school maintenance routine what type fluid? DOT 5 OVER time will do that. It is the worse as absorbs moisture.
But all fluid can. So...
Last was last time brakes were treated to a good bleeding? Manually adjust by you in rear if auto ones have not been doi g a good job.
If calipers are no leak? Sticky ? If no to both you could still just get kits to do a look see. Clean, look see, and hone, clean, assemble.
Some new parts are trash. I try to always refresh the ones I have now. (Ie) May be better and just do the needed maintenance or quick rebuild.
Hey ya did it back when nothing was available, or to poor to get new! And with new stuff being junk to me it's the same [i][/i]as none offered. Maybe worse as you don't want to take better parts off than you are putting on.
I rebuilt my calipers, but found NOS wheel cylinders, old stock master cylinder kit, and has been a long time but new rubber for booster and tested check valve.
Could check and if need be Booster Dewy (so?)
I am kinda an idiot but bought extra drums and rotors when i saw things getting out sourced. But you can find them good USA Raybestos, Bendix, etc good to get just to have and pads, shoes they don't eat food they just sit and wait.
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: E-Body Brake Booster/Master Cylinder Replacement [Re: 340SIX] #3144314
05/13/23 07:29 AM
05/13/23 07:29 AM
Addison Twp, Mi.
RobG Offline OP
RobG  Offline OP
Addison Twp, Mi.
Hello gents - here is more information that you requested:
WHen i push the brake pedal, I am getting a "wooosh" sound - as if the brake booster is leaking. I am also seeing a leak in the master cylinder seals. The pedal is going almost all the way down when the car stops.
I can bleed the brakes and flush the system - that hasn't been done in 20 years, but I believe the booster is the main issue on the front disc/rear drum setup on mu Cuda. As hard as I try, I cannot get the brakes to lock-up..
Re: E-Body Brake Booster/Master Cylinder Replacement [Re: RobG] #3144394
05/13/23 02:10 PM
05/13/23 02:10 PM
moparx Offline
moparx  Offline
well, the "woooosh" sound sure "sounds" [biggrin] like the booster diaphragm is bad, and that also would explain why you can "put both feet on the brake pedal and stand up, trying to pull the steering wheel off", and the car doesn't stop as it should.
beer
Re: E-Body Brake Booster/Master Cylinder Replacement [Re: moparx] #3144526
05/14/23 10:37 AM
05/14/23 10:37 AM
ILL
Greentween Offline
Greentween  Offline
ILL
The woosh sound is because there is packing in the input side of the booster that acts a a muffler. It is worn out or missing. Got to pull the booster to replace it so might as well just replace the booster.
Re: E-Body Brake Booster/Master Cylinder Rplacement [Re: Greentween] #3144655
05/15/23 07:42 AM
05/15/23 07:42 AM
Addison Twp, Mi.
RobG Offline OP
RobG  Offline OP
Addison Twp, Mi.
So who has a good booster at a reasonable price? What remanufactured units do you think are good?
Re: E-Body Brake Booster/Master Cylinder Replacement [Re: RobG] #3144680
05/15/23 09:42 AM
05/15/23 09:42 AM
Cab_Burge Online work
Cab_Burge  Online Work
I would take the time to figure out what part is not working properly before starting to replace any parts on your car,, fix it first wrench scope twocents
Air in one wheel cylinder will make the brake pedal soft work scope
Re: E-Body Brake Booster/Master Cylinder Replacement [Re: Cab_Burge] #3147301
05/28/23 07:47 PM
05/28/23 07:47 PM
The Garden State
LimelightCuda Offline
The Garden State
If it were me I would rebuild your the booster you have rather than buying one from a local auto parts store. I believe these guys can rebuild it.
(IF you do determine it is the booster.)
https://www.powerbrakebooster.com/
I haven't had good luck with new after market parts but that is just my experience.
Phil
1970 Barracuda Gran Coupe
1970 A66 Challenger Convertible
