Goodyear radial drag slicks ?
#3144074
05/12/23 04:42 AM
05/12/23 04:42 AM
Posts: 2,469 Sydney,Australia
tex013
Sydney,Australia
Anyone using these , specifically the D4827 30 x9 R15 .or the newer 30x9 for FSS cars Looking at running these for bracket racing on my Plymouth footbraking . Tracks normally ok though not stellar nor specific radial prep . I cannot get PBRs , 29,5x10.5R15 , as zero stock . I have got Hoosier 30x10.5R15 radial slicks but they are nearly done and by crikey the price is up . The PBRs i would get up around 180 passes the Hoosier are under 80 . Any thoughts appreciated
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
Re: Goodyear radial drag slicks ?
[Re: racerx]
#3144230
05/12/23 05:58 PM
05/12/23 05:58 PM
tex013
Sydney,Australia
Talk to a Goodyear Rep this past weekend at the Superbowl he said they were stepping up production on the PBR's. Talked to distributer here - been on back order since August apparently . No date or idea of supply Tex
[Re: 66coronet]
#3144231
05/12/23 06:00 PM
05/12/23 06:00 PM
tex013
Sydney,Australia
I have not run them but I did look at the Good year radials on a few cars at Rockingham and St Louis. I talked to the folks at the Mickey Thompson truck and they told me the PBR was ramped up in production. I am running the hoosier radial now since I couldnt get the PBR and to me it is more of a bias than a PBR radial looking at my log book data. I am in same boat as you running Hoosier . As footbrake my data seems to show a little quicker ET on them . They dont seem as happy running off transbrake . I can buy Hoosier but over $600.00 each Tex
[Re: 69dart]
#3144233
05/12/23 06:03 PM
05/12/23 06:03 PM
tex013
Sydney,Australia
We found a set of 28x9's at the Jegs store about a month ago.
Sometime they sell them in store before listing them as they go so fast. Jegs list the 29.5s but after i factor freight its more than $1500 Aussie pesos delivered . I may have to look at freight forwarder ? Thanks everyone for replies . But do anyone but Stock/Superstock run the Goodyear ? Tex
[Re: tex013]
#3145576
05/19/23 01:44 PM
05/19/23 01:44 PM
Triple Threat
Renton Washington
I've run the 30x9 Goodyear radial on both my Dart, and my Stocker. Good tire, lasts a long time. I have friends that run them in the low 1.3 to high 1.2 second 60 foot range for 150+ runs before changing.
If you can get those locally i dont think you'd be unhappy, as long as your track is prepped decently.
Edit: I've seen both the FSS 30x9 in person next to the older style, if you can fit it definitely worth using the bigger FSS tire
[Re: Triple Threat]
#3145700
05/20/23 03:36 AM
05/20/23 03:36 AM
tex013
Sydney,Australia
Thanks Dustin , I did buy the GY this past week . Price was good and they were made in 11/22 . From my thoughts feel the GY has a stiffer sidewall than Hoosier . They dont have the newer GY at moment , its on order but could be a few months away and Hoosier was onto cords What air pressure range did you use ? I have them on a 10" rim and will start with 19psi , same as Hoosier and MT ive used . Regular 4/5 second burnout out and drive out or ? 125/150 passes would be great . Thanks for your input . Tracks here are ok mostly . 🤞
Tex
[Re: LA360]
#3146094
05/21/23 11:01 PM
05/21/23 11:01 PM
tex013
Sydney,Australia
Alan , about 20% or so cheaper per tyre Got a pair and organising a 2nd pair for Chevy
Tex
[Re: tex013]
#3146396
05/23/23 01:51 PM
05/23/23 01:51 PM
Triple Threat
Renton Washington
19 should be in the ballpark We had goodluck doing short burnouts, just get them spinning and lightly smoking as driving out. Doesn't need much. That will help with life as well.
[Re: Triple Threat]
#3146439
05/23/23 05:42 PM
05/23/23 05:42 PM
tex013
Sydney,Australia
19 should be in the ballpark We had goodluck doing short burnouts, just get them spinning and lightly smoking as driving out. Doesn't need much. That will help with life as well. Thanks Dustin Tex
