Wheel/Tire Size Help #3143929
05/11/23 01:54 PM
05/11/23 01:54 PM
London, England
JFChallenger440 Offline OP
London, England
Any idea what tire size would fill the top of the arch better ?
I don’t like that gap above the tire between the arch
I’m thinking maybe going 70 profile like a 255/70/15 ?
Below are pics of it with
15 x 8 (I think)
5” BS
275/60/15’s
1.25” spacer
And I still have a lot of room to spare
The wheels I want I have to decide between
15 x 10 with 4” BS
Or
15 x 8 with 3.75”
It seems my car is a little raised at the rear so I don’t think I’ll have a problem with rubbing on those backspacing but I would just like the gap between the top of the tire and arch to be a bit fuller , that’s why I thought maybe a 70 profile
P.S the car is not on the Jack in the pics , I had just lowered it down
Re: Wheel/Tire Size Help [Re: JFChallenger440] #3143937
05/11/23 02:26 PM
05/11/23 02:26 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
To me, the car just looks too high. I'd want to lower it about 2".
But I agree on filling the wheelwell, and not seeing a gap above the tire.
But yes, a 70-series will tend to fill the opening a bit better; but it's likely to be a taller tire.
FWIW: I'm not a fan of what we in the US call a tire-cross; hope you have a proper socket, extension & etc for the lug nuts.
Re: Wheel/Tire Size Help [Re: topside] #3143952
05/11/23 03:45 PM
05/11/23 03:45 PM
London, England
London, England
Thanks for the reply
So a 255/70 should fill that gap at the top a bit better ?
I actually really like 70 profile tires from the pics I’ve seen
Re: Wheel/Tire Size Help [Re: JFChallenger440] #3143963
05/11/23 04:30 PM
05/11/23 04:30 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
A 275/60 is about 28" tall, and a 255/70 is close to 30", IIRC.
So, it's about an inch at the top.
I've had 255/70s on 8" wheels, and they looked fine; 10" wheels are probably too wide for them, though.
Re: Wheel/Tire Size Help [Re: topside] #3143994
05/11/23 07:17 PM
05/11/23 07:17 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
This.
It’s not the tire. It’s the car. It’s too high.
Re: Wheel/Tire Size Help [Re: BSB67] #3144003
05/11/23 08:12 PM
05/11/23 08:12 PM
London, England
London, England
What’s the easiest way to lower the rear ?
The front sits a little high too though so I guess would have to lower that as well
The pics below , the wheel/tire sizes are
Rear - 15 x 8
3.75” BS
295/50/15
Front
15 x 7
3.75” BS
235/60/15
Re: Wheel/Tire Size Help [Re: JFChallenger440] #3144022
05/11/23 09:37 PM
05/11/23 09:37 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Rear: least expensive would be lowering blocks. You might need longer U-bolts. Optimally it's rear springs with less arch.
Front: torsion bar adjustment bolts, basically unscrew them a bit.
Make sure you leave a gap at the control arm bumpers, though; usually about 1" is OK, as they're inboard of the arc of travel.
Re: Wheel/Tire Size Help [Re: topside] #3145291
05/18/23 10:38 AM
05/18/23 10:38 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
In my opinion the 275-60-15 is the perfect "Day 2" muscle car mod. Its height of near 28" and its 11" section width compliment a muscle car- especially the larger bodies like Mopar B body. The 70 series gets too narrow (again- my opinion.) Id run the 275s and try some lowering blocks. You can get a taller tire with the same width as the 275-60-15 but NOT in raised white letters. The Hoosier and MT pro street radials have a nice assortment of sizes but 1- Are insanely $$. 2- None available. 3- Blackwall only.
Keep old mopars alive.
