Tire and wheel size helpAnd sidewall flexibility #3142507
05/04/23 01:49 PM
05/04/23 01:49 PM
nesbit,ms.
70sate Offline OP
70sate  Offline OP
nesbit,ms.
Hey guys it's been awhile. trying to figure out what size tires and wheel combination would be best for a 69 Dodge Charger stock spindles
On Magnum Transformer K member stock rear end I'm wondering about diameter size so I can avoid any rubbing issues and a proper size for good looks and sidewall cushion I'm leaning towards 17 inch Wheels on the front and 18s on the back probably 7-in wide on the front can I go 9 or 10 on the back?,
Re: Tire and wheel size helpAnd sidewall flexibility [Re: 70sate] #3142629
05/05/23 07:02 AM
05/05/23 07:02 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Probably not the right forum for the question, street rods don't fall into the musclecar category, might have a lot more visibility in the main forum, probably already has the answer too, if you do a search.
But here is how I sorted out what sized tires I could fit under my 51.
http://www.yourolddad.com/tires
Re: Tire and wheel size helpAnd sidewall flexibility [Re: Sniper] #3142694
05/05/23 01:52 PM
05/05/23 01:52 PM
nesbit,ms.
70sate Offline OP
70sate  Offline OP
nesbit,ms.
Ok Thanks
Re: Tire and wheel size helpAnd sidewall flexibility [Re: 70sate] #3143063
05/07/23 03:56 PM
05/07/23 03:56 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
IDK how much this will help I have 295/55/15 w/5x5bs [28"tall tire fyi]
