Hey guys it's been awhile. trying to figure out what size tires and wheel combination would be best for a 69 Dodge Charger stock spindles
On Magnum Transformer K member stock rear end I'm wondering about diameter size so I can avoid any rubbing issues and a proper size for good looks and sidewall cushion I'm leaning towards 17 inch Wheels on the front and 18s on the back probably 7-in wide on the front can I go 9 or 10 on the back?,
Probably not the right forum for the question, street rods don't fall into the musclecar category, might have a lot more visibility in the main forum, probably already has the answer too, if you do a search.
But here is how I sorted out what sized tires I could fit under my 51.
http://www.yourolddad.com/tires
