World Aluminum Block Roller Lifter? #3142913
05/06/23 10:06 PM
05/06/23 10:06 PM
Portland, Oregon
Digger73 Offline OP
Digger73  Offline OP
Portland, Oregon
I am building my first aluminum big block and I just found out that my solid roller lifters will not work.
The lifters I ran in my stock cast iron block are tall enough but. The tie bar hits the casting for the HEMI head studs.
So I am looking for new lifters. What have worked for you guys? Part numbers would be greatly appreciated.
Thanks,
Digger73 (Mike)
I live with fear everyday but, sometimes she lets me race!
Re: World Aluminum Block Roller Lifter? [Re: Digger73] #3142928
05/06/23 11:07 PM
05/06/23 11:07 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
You got a pic of this? I'm struggling to understand how it would touch from down in the valley.
Re: World Aluminum Block Roller Lifter? [Re: Digger73] #3142935
05/06/23 11:36 PM
05/06/23 11:36 PM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
Yes what do you have now? Not possible to flip them so the tie bar is inboard?
Re: World Aluminum Block Roller Lifter? [Re: rebel] #3142941
05/06/23 11:49 PM
05/06/23 11:49 PM
Portland, Oregon
Digger73 Offline OP
Digger73  Offline OP
Portland, Oregon
The tie bar hits the casting where if the block were for a HEMI the head studs would go.
Re: World Aluminum Block Roller Lifter? [Re: Digger73] #3142945
05/07/23 12:04 AM
05/07/23 12:04 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Can you grind a little clearance in those bosses?
Re: World Aluminum Block Roller Lifter? [Re: slantzilla] #3142947
05/07/23 12:11 AM
05/07/23 12:11 AM
Portland, Oregon
Digger73 Offline OP
Digger73  Offline OP
Portland, Oregon
I am not sure? I even considered grinding the clearance in the tie bars. But I wasn't sure if that would make the tie bars too weak.
Re: World Aluminum Block Roller Lifter? [Re: Digger73] #3142970
05/07/23 07:03 AM
05/07/23 07:03 AM
What brand of lifters are those?
They don't look like any I have seen for B/RB or gen 2 hemi blocks work shruggy
Re: World Aluminum Block Roller Lifter? [Re: Cab_Burge] #3142978
05/07/23 08:11 AM
05/07/23 08:11 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Maybe you could grind a little on the boss and a little on the tie bar. Welcome to the world of building engines with aftermarket parts.
2011 Drag Pak Challenger
Re: World Aluminum Block Roller Lifter? [Re: Cab_Burge] #3142990
05/07/23 10:04 AM
05/07/23 10:04 AM
Portland, Oregon
Digger73 Offline OP
Digger73  Offline OP
Portland, Oregon
I don't know the brand. I bought the lifters from a member here years ago and I don't think they ever told me. frown
Re: World Aluminum Block Roller Lifter? [Re: rickseeman] #3142995
05/07/23 10:13 AM
05/07/23 10:13 AM
Portland, Oregon
Digger73 Offline OP
Digger73  Offline OP
Portland, Oregon
I have a feeling that is just what I am going to wind up doing. I never would have thought that my lifters would be such a huge stumbling block.
Re: World Aluminum Block Roller Lifter? [Re: Digger73] #3143017
05/07/23 12:15 PM
05/07/23 12:15 PM
central il.
second 70 Offline
second 70  Offline
central il.
I think Zippy had a problem like that on a mega block and got taller lifters. might pm him.
Re: World Aluminum Block Roller Lifter? [Re: Cab_Burge] #3143028
05/07/23 12:53 PM
05/07/23 12:53 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
I agree, the ones I've seen have a vertical link bar facing the centre of the valley ??
Re: World Aluminum Block Roller Lifter? [Re: Tig] #3143041
05/07/23 02:40 PM
05/07/23 02:40 PM
Portland, Oregon
Digger73 Offline OP
Digger73  Offline OP
Portland, Oregon
You wouldn't happen to have a recommendation for lifters that would work with the World aluminum block?
The lifter bosses are taller than a stock block and that is where I am having problems. The lifters I have, the tie bars are keeping the lifters from making contact with the cam lobes.
There has to be a solid roller that will work with this block?
Re: World Aluminum Block Roller Lifter? [Re: Digger73] #3143049
05/07/23 03:00 PM
05/07/23 03:00 PM
Any of Comp Cams current .904 solid roller are made for the newer taller lifter bore blocks, iron or aluminum.
I would call them to get the correct ones for your aluminum block, I think that the chrome ones were correct for any and all aluminum blocks scope confused
Re: World Aluminum Block Roller Lifter? [Re: Cab_Burge] #3143055
05/07/23 03:10 PM
05/07/23 03:10 PM
Sticky South
Rodenteliminator Offline
Sticky South
Do you have a picture from back to see the complete setup ? Doug
Sorry honey I spent the rent
Re: World Aluminum Block Roller Lifter? [Re: Rodenteliminator] #3143056
05/07/23 03:12 PM
05/07/23 03:12 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
The BAM lifters are all the tall body type.
