Page 1 of 3 1 2 3
Finally DONE! What will it run?!?!? #3142436
05/04/23 08:19 AM
05/04/23 08:19 AM
Oakland, MI
dizuster Offline OP
dizuster  Offline OP
Oakland, MI
Well after about a year and a half of work, my '62 is finally converted over from the old small block turbo combo and ready to run.
I have had so much help from so many people, but more than anyone my Dad (dvw) has just put in HUNDREDS of hours into this car. No doubt I would have eventually gotten it done, but no where near the quality and craftsmanship level he brought to the project. Not to mention the hours my Mom put in helping on the interior, giving up time with my Dad, and keeping us alive!
HardcoreB built a hell of a motor for the combo too, and went above and beyond the original commissioned engine build he took on.
So here is the combo, and the obligatory moparts question for any new build.... what will it run?
3570lbs with driver ready for the starting line (heavier than I was hoping!)
4.10 Dana with Caltracs, 29.5 x 10.5 Pro Bracket Radials, and Mencer Double Adjustable Afco's
727 with good strong parts and Aluminum Drum.
TA 8" converter spec'd for the combo (target 6200 stall)
486" Low Deck (4.385" bore x 4" stroke)
Indy SR Heads, w/ 2.25" ti valves (flow 360cfm?)
275@.050 / .762" Lift Roller Cam, T&D 1.6 rockers, with PAC Springs
Crower Ultra light crank, BME Aluminum Rods, with flat top pistons (12.2:1 compression)
Hooker 2-1/8" headers with 3.5" collector
Mod Man intake (which we named the SeanMan after the heavy runner length/porting/design changes of HardcoreB's work.)
Two 750 AFB's
Electric water pump & Vacuum pump pulling 10~12"
Re: Finally DONE! What will it run?!?!? [Re: dizuster] #3142437
05/04/23 08:21 AM
05/04/23 08:21 AM
Oakland, MI
dizuster Offline OP
dizuster  Offline OP
Oakland, MI
Really happy with the interior.
Re: Finally DONE! What will it run?!?!? [Re: dizuster] #3142438
05/04/23 08:26 AM
05/04/23 08:26 AM
Oakland, MI
dizuster Offline OP
dizuster  Offline OP
Oakland, MI
Engine
Re: Finally DONE! What will it run?!?!? [Re: dizuster] #3142444
05/04/23 08:44 AM
05/04/23 08:44 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
By the way the engine sounds, it will run 9.90's, but I think the 4.10's might slow it down some, and need a 4.56 rear gear. Just My opinion. I think 10.25's are reasonable.
69 GTX 68 Road Runner
Re: Finally DONE! What will it run?!?!? [Re: JERICOGTX] #3142457
05/04/23 09:39 AM
05/04/23 09:39 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
No really good at these guessing games but I’m sure it will run great. Nice job guys. Now go have fun.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Finally DONE! What will it run?!?!? [Re: pittsburghracer] #3142462
05/04/23 10:07 AM
05/04/23 10:07 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
It will run strong and look great doing it! Built with LOVE boogie
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Finally DONE! What will it run?!?!? [Re: pittsburghracer] #3142464
05/04/23 10:11 AM
05/04/23 10:11 AM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
Thinking 9.80's at Lapeer or Martin, and 10.20's at Milan if you go on a night when they aren't radial prepping. The car looks outstanding, love the interior and patina!
Re: Finally DONE! What will it run?!?!? [Re: pittsburghracer] #3142466
05/04/23 10:13 AM
05/04/23 10:13 AM
an8sec70cuda Offline
Awesome job! I'm gonna say 9.70s-9.80s. shruggy
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Finally DONE! What will it run?!?!? [Re: an8sec70cuda] #3142475
05/04/23 10:45 AM
05/04/23 10:45 AM
gregsdart Offline
gregsdart  Offline
First off , beautiful job on the build!
my WAG: 10.02 at 133 mph.
Re: Finally DONE! What will it run?!?!? [Re: gregsdart] #3142477
05/04/23 11:13 AM
05/04/23 11:13 AM
Lake Villa Il
INTMD8 Online content
INTMD8  Online Content
Lake Villa Il
No idea what it will run but certainly looks awesome. Nicely done.
Re: Finally DONE! What will it run?!?!? [Re: gregsdart] #3142479
05/04/23 11:19 AM
05/04/23 11:19 AM
S.E. Michigan
TruPerformance Offline
S.E. Michigan
I'm going to guess 9.70's @ around 136 for the first outing, then you guys will continue to drop from there.... probably a 9.50 or better in it before the year is over.
1963 Belvedere (mine)
1969 Roadrunner (wife's)
Re: Finally DONE! What will it run?!?!? [Re: dizuster] #3142514
05/04/23 02:12 PM
05/04/23 02:12 PM
Cab_Burge Online work
Cab_Burge  Online Work
I've thought about building a 4.0 stroke B/RB stroker motor but haven't built one yet realcrazy, maybe next year luck I've built more than one 3.91 stroke B and Rb motors and 4.150, 4.250, 4.320 and several 4.375 strokers with stock Mopar rod jourmnal sizes, never again using the 2.375 rod journal diameter by choice twocents
What made you decide to use that stroke?
I'm thinking that combination will like RPM bowdevil up
Re: Finally DONE! What will it run?!?!? [Re: dizuster] #3142517
05/04/23 02:18 PM
05/04/23 02:18 PM
K
Kiddart Offline
Kiddart  Offline
K
you guys do great stuff, you looking to adopt a brother or a son???
I cant wait to hear how it runs.
Thank you
Kiddart
Re: Finally DONE! What will it run?!?!? [Re: dizuster] #3142518
05/04/23 02:21 PM
05/04/23 02:21 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
I will guess 10.0 in some good air - 10.25 in the summer - The interior came out killer! surprised its so heavy - but then again mine is 3800 with me in it and I have a glass hood and bumpers
Re: Finally DONE! What will it run?!?!? [Re: Kiddart] #3142520
05/04/23 02:21 PM
05/04/23 02:21 PM
Chesterfield Twp. Mi.
John Burdine Offline
It will go 9's, no doubt. May like a bit more gear (4.30 or 4.56). Curious to here how the Ken Keir wheelie bars work with Caltracs.
Re: Finally DONE! What will it run?!?!? [Re: John Burdine] #3142529
05/04/23 03:03 PM
05/04/23 03:03 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Looks very nice
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Finally DONE! What will it run?!?!? [Re: Cab_Burge] #3142550
05/04/23 07:05 PM
05/04/23 07:05 PM
gregsdart Offline
gregsdart  Offline
i
Cab, years ago i built a 475 cube rb motor out of a stock crank cut to 2.10 sbc size at 4.0 inch, using a BME 396 aluminum custom rod. It worked great for what it was. The rod was 7.10 long, which fit some stroker pistons i had from a motor that broke a crank. The 2.10 bearings held up well, and the second owner got a lot of life out of it
Re: Finally DONE! What will it run?!?!? [Re: gregsdart] #3142560
05/04/23 07:48 PM
05/04/23 07:48 PM
i
up workThanks
Re: Finally DONE! What will it run?!?!? [Re: gregsdart] #3142561
05/04/23 07:50 PM
05/04/23 07:50 PM
Oakland, MI
dizuster Offline OP
dizuster  Offline OP
Oakland, MI
This is a 2.100", BME rod combo.
I'm sure it's going to want some RPM with that light rotating Assy. 2.25" Ti intake, and big bore!
Thanks for all the love...heading to Stanton tomorrow for the weekend.
Re: Finally DONE! What will it run?!?!? [Re: dizuster] #3142581
05/04/23 09:22 PM
05/04/23 09:22 PM
Heaven
EvilB1Dart Offline
EvilB1Dart  Offline
Heaven
That's another one of the cool cars on here. I bet its going to run 9.80's.......but I think it's going to want 4.56's back there.
"Any fool can know. The point is to understand"
- A. Einstein
Page 1 of 3 1 2 3
