Re: 1970 Charger OEM Disc Brake Caliper Location
[Re: charge70]
#3142207
05/03/23 09:50 AM
05/03/23 09:50 AM
Posts: 4,576 Motor City
6PKRTSE
Motor City
They go towards the rear.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 70X]
#3142250
05/03/23 11:53 AM
05/03/23 11:53 AM
Posts: 1,710 central il.
second 70
central il.
Front 70 Cuda. Also hiding place for my MSD coil. Lol
My calipers are 70 but the disc are the later bigger bearing hubs.
Mike
[Re: second 70]
#3142256
05/03/23 12:14 PM
05/03/23 12:14 PM
Posts: 5,924 ohio
ruderunner
ohio
Front. Part of the reason why the sway bar was redesigned was to make room for the single piston caliper.
Angry white pureblood male
[Re: ruderunner]
#3142282
05/03/23 01:37 PM
05/03/23 01:37 PM
Posts: 2,368 Wheatfield, NY
Cuda340
Wheatfield, NY
Front. Part of the reason why the sway bar was redesigned was to make room for the single piston caliper. This! Front side
[Re: 70X]
#3142340
05/03/23 05:13 PM
05/03/23 05:13 PM
Posts: 43,274 Bend,OR USA
Cab_Burge
Swapping the spindles so the calipers mount behind the spindles moves that weight to the rear which help the cars I've done that on stop and corner better. The skinny front drag tires didn't lock up as easy after moving them it's your choice, show or go?
[Re: dragon slayer]
#3142452
05/04/23 09:15 AM
05/04/23 09:15 AM
Posts: 18,426 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
70-72 KH Single piston was B and E body. So assuming that these are original they would be front mounted, but not sure how they could even be mounted in the rear. Spindles and Calipers were Right/Left specific. I can only state what the FSM shows. Was 69 disc to the rear? Could there be an up to and after build? Parts manual may clear this up.
[Re: NITROUSN]
#3142484
05/04/23 11:45 AM
05/04/23 11:45 AM
Posts: 75,082 U.S.S.A.
JohnRR
U.S.S.A.
70-72 KH Single piston was B and E body. So assuming that these are original they would be front mounted, but not sure how they could even be mounted in the rear. Spindles and Calipers were Right/Left specific. I can only state what the FSM shows. Was 69 disc to the rear? Could there be an up to and after build? Parts manual may clear this up. 69 down calipers were to the rear , 70 they moved to the front . The spindles are not side specific as far as I know ... but I don't know everything
[Re: dragon slayer]
#3142625
05/05/23 05:53 AM
05/05/23 05:53 AM
Posts: 5,924 ohio
ruderunner
ohio
My 69 Roadrunner had 4 piston disc mounted to front. I changed to the big rotors and single piston.
[Re: ruderunner]
#3142739
05/05/23 09:00 PM
05/05/23 09:00 PM
NITROUSN
My 69 Roadrunner had 4 piston disc mounted to front. I changed to the big rotors and single piston. 69 Is to the rear. FSM clearly states the Bendix and KH are mounted to the rear of the steering axis. FSM illustrates it also. Parts manual also shows it. 69 also had a short steel brake line from the hose to the caliper. 70 went to the front and the hose screwed directly into the caliper.
[Re: NITROUSN]
#3142957
05/07/23 04:04 AM
05/07/23 04:04 AM
Posts: 154 Missouri
70X
Missouri
They go towards the rear. The 70 Charger FSM shows them mounted to the rear. I know, that's why I asked the question. I'm leaving them in the front. Thanks for all of your help guys!
[Re: 70X]
#3142963
05/07/23 06:04 AM
05/07/23 06:04 AM
Posts: 5,924 ohio
ruderunner
ohio
Let me throw this out there, where does the hard line come to? Ahead or behind the knuckle?.
My understanding is the hose should cross the steering axis, so hard line at back means caliper to front and vice versa.
[Re: ruderunner]
#3142982
05/07/23 09:04 AM
05/07/23 09:04 AM
NITROUSN
My understanding is the hose should cross the steering axis, so hard line at back means caliper to front and vice versa. Front of knuckle has hose screwed into the caliper. Rear of knuckle has a short steel line between the hose and the caliper. I posted differences in the hoses above.
