Attaching a engine puller #3141495
04/30/23 11:02 AM
04/30/23 11:02 AM
California
GTXMEX Offline OP
GTXMEX  Offline OP
California
OK to attach an engine pull chain device to the headbolt holes of a bare block? I need to move block from stand to my truck and was thinking to attach the four chains to each corner using head bolts.
Re: Attaching a engine puller [Re: GTXMEX] #3141503
04/30/23 11:38 AM
04/30/23 11:38 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
We have done it tons of times. In the past.
Now we use old serpentine belts through the cylinders. The local speed shop seen me do it that way and now that is the way they move their blocks.
Most salvage yards have many just laying around and will let you scrounge a few for nothing.
Master, again and still
Re: Attaching a engine puller [Re: GTXMEX] #3141536
04/30/23 01:53 PM
04/30/23 01:53 PM
I do that all the time with a 3/8 chain wrench up
Re: Attaching a engine puller [Re: Cab_Burge] #3141540
04/30/23 02:24 PM
04/30/23 02:24 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
easiest way is flip it upside down, put the center main cap on and use a old v-belt through the cap.
Brian
Re: Attaching a engine puller [Re: GTXMEX] #3141756
05/01/23 02:09 PM
05/01/23 02:09 PM
California
GTXMEX Offline OP
GTXMEX  Offline OP
California
Anyone ever asks to bolt to head bolt holes on block to lift it...just say no. :-(
Re: Attaching a engine puller [Re: GTXMEX] #3141799
05/01/23 04:54 PM
05/01/23 04:54 PM
Why? confused
Or are you saying with the heads on the block to not use the head bolts? shruggy
If so, I agree up
Re: Attaching a engine puller [Re: Cab_Burge] #3141833
05/01/23 06:17 PM
05/01/23 06:17 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
You guys using old V-belts or serpentines are....let's say, brave.
If they'll break driving a fan & alternator...no thanks.
I use seat belt webbing if a chain won't work.
I'd prefer accessory/bell housing threads to head bolt threads, but I've used the carb-mount plates on my SB motors (which isn't what the OP was asking).
Pretty much depends on the task at hand.
Re: Attaching a engine puller [Re: topside] #3141851
05/01/23 08:04 PM
05/01/23 08:04 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Seat belts are okay in certain circumstances. But how much experience do you have lifting with serpentine belts? Sounds like none.
I have seen engines lifted with them for years and years. As long as the belts are in good shape, it's all good. We have also used them to pull stuck mowers and many other things. When we have overloaded them pulling something more than we should have with them, we are always surprised just how much they would pull before failure.
For a serpentine belt in good shape, lifting an engine is no problem. Done it and seen it done dozens and dozens of times.
If you have reservations with them, don't use them. But real world experience with them does count for something.
Re: Attaching a engine puller [Re: DaveRS23] #3141871
05/01/23 09:14 PM
05/01/23 09:14 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
You are correct, sir: absolutely zero experience with that.
To me, a "used drive belt" means its strength is compromised, and it was replaced rather than risk failure.
Glad it works - so far - for those who use that method, though.
Re: Attaching a engine puller [Re: GTXMEX] #3141986
05/02/23 12:29 PM
05/02/23 12:29 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Wherever possible, the fastener (bolt, stud) should only be loaded in shear (90° to its length), not tension.
I would never use an accessory belt.
Bare block: seat belts through the bores, wrapped around a 6" piece of 2 × 4 wood below the bores.
Boffin Emeritus
Re: Attaching a engine puller [Re: polyspheric] #3142123
05/02/23 09:13 PM
05/02/23 09:13 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I'm going to make an engine sling out of my old outdated belts. They should be plenty strong enough.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Attaching a engine puller [Re: GTXMEX] #3142151
05/02/23 10:51 PM
05/02/23 10:51 PM
AndyF Offline
AndyF  Offline
We move bare blocks around the shop all day long with old fan belts around the main caps. A bare block is only a couple hundred pounds. If you rig up a fan belt in a pull rig it will hold a few thousand pounds before it breaks. The fibers inside a fan belt are super strong in tension.
Re: Attaching a engine puller [Re: topside] #3142210
05/03/23 09:56 AM
05/03/23 09:56 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Not at all. As I mentioned earlier, the salvage yards are full of belts that were fully serviceable when the vehicle was killed. A simple close examination will reveal it's condition. Same as with a chain or anything else you would lift with.
No one is trying to convince you to use anything other than what you are currently using. You are only looking for reasons to support your decision not to use belts while ignoring many, many real experiences with them.
Carry on.
Re: Attaching a engine puller [Re: DaveRS23] #3142222
05/03/23 10:19 AM
05/03/23 10:19 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Jeez, Dave, feeling argumentative ? Superior ?
I'm not ignoring or justifying anything, merely stating my preference and why.
On some things, I don't want to take a chance; maybe that's paranoid and ignorant, but I'm cautious about some things.
Like swinging 600 lbs over my cars' fenders.
For just moving stuff around, the drive belt thing is pretty clever.
Have a nice day.
Re: Attaching a engine puller [Re: DaveRS23] #3142313
05/03/23 03:45 PM
05/03/23 03:45 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Accessory belts' service life is based on continuous tension, with minimal start-up torque load (cranking).
Seat belts are designed to accept huge instant torque loads (no G force = no torque).
If you use an accessory belt, don't let the weight bounce ("take up the slack") when lifting.
Boffin Emeritus
Re: Attaching a engine puller [Re: topside] #3142366
05/03/23 08:02 PM
05/03/23 08:02 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Have a nice day.
Neither argumentative nor superior. Just correcting your erroneous assumption that the belts must have been worn out when removed from service. You would want to know the truth, wouldn't you?
And you are the only one to bring up "swinging 600 lbs over my cars' fenders". Jeez! eyes
