How interchangeable are mopar steering wheels?
#3141548
04/30/23 03:27 PM
04/30/23 03:27 PM
Posts: 11,508 delivering your oil
nutso suave
delivering your oil
How interchangeable are mopar steering wheels? Can you install a 66 wheel on a 69 column? or a 72 wheel on a 68 column? I also noticed most aftermarket wheels seem to be 15" in diameter while factory wheels are usually 16". My limited google research indicates that the 70 wheel is 1/2 larger diameter than the 69 and earlier (non tilt models) in order to accommodate the ignition being integrated into the column. It sounds like the spline count is the same...has anyone done this?
Thanks in advance.
Re: How interchangeable are mopar steering wheels?
[Re: nutso suave]
#3141609
04/30/23 09:01 PM
04/30/23 09:01 PM
Posts: 10,653 Freeport IL USA
poorboy
Freeport IL USA
As best as I can explain it, there are eras of steering wheel fitments, and then you add trim matching between the column and the wheel. This becomes important between many tilt or non-tilt columns/wheels. I can't give you specific beginnings or ends there are also differences between truck and car wheels, to some extent. Sometimes, there were model to model differences.
The early Mopars had a hollow column and the horn wire ran through the column. The hollow column is a larger diameter so the newer wheel hubs won't fit those early columns. Those ended somewhere in the 62-63 time frame. The next era would have ended around 69-70, or when the ignition moved from the dash to the column. With the lock and switch in the column the column diameter got larger, and those wheels grew latger at the column contact point. The addition of the tilt caused some issues in the early tilt column years, until the tilt and the non-tilt became uniform in diameter, probably the end of 73/74. Things bumped along pretty well until the air bags came out starting in 88, but not everything got an air bag until around 93. The air bag column has everything different from a non-air bag column.
After the hollow shaft went away, the steering wheels may well fit the steering column shaft, and the spline count, but things like the bottom of the wheel might not fit around the column, the horn ring may be different, or the turn signal cancel pegs might not work. The interface between the top of the column and the bottom of the wheel might not work well together.
I believe the steering wheel adaptors for aftermarket wheels fit columns from the mid 60s up through the early 90s, with a few exceptions thrown in for good measure. The aftermarket adaptors have generic connections for horn function and turn signal cancelation. and a cover adaptor to blend with the top of the column. The bottom of the aftermarket steering wheels are all flat and flush with the bottom of the wheel where the adaptor attaches. probably not what you wanted to hear, but this has been my experience over the years.
[Re: nutso suave]
#3141652
05/01/23 03:05 AM
05/01/23 03:05 AM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
The main change I know, was on 70 when the steering column diameter becomes larger to accept the ign switch. This make the pre 69 steering wheels won’t match with post 70 columns, and of course, backwards.
[Re: NachoRT74]
#3141656
05/01/23 06:02 AM
05/01/23 06:02 AM
Posts: 5,960 ohio
ruderunner
ohio
To clarify the above, newer wheels will attach to the older column, but the cosmetics are off due to different jacket diameter.
I have an 83 truck wheel on my 69 column.
Angry white pureblood male
[Re: nutso suave]
#3141817
05/01/23 05:46 PM
05/01/23 05:46 PM
Posts: 5,960 ohio
ruderunner
ohio
ruderunner - do you have any pictures? thanks! Nothing handy right now. But basically the collar at the base of the wheel is larger diameter than the bowl of the column. It's not a huge difference but noticeable. Cancel cam and horn contacts matched up.
