Removing primer overspray on upholstery ? #314109
05/10/09 08:33 PM
05/10/09 08:33 PM
CT - just outside Hartford
Crazy73 Offline OP
Crazy73  Offline OP
I just unearthed the '68 Barracuda from storage and noticed a few drops of primer overspray on my new black vinyl seats (Legendary Int, from Dante). Evidently the interior wasn't properly masked off when the inside of the doors were shot. It seems to be one setback after another with this car, I can't wait to finish it and get rid of it.
Can I use paint thinner or "oops" to safely remove the droplets?
Pete
-1968 Barracuda 4spd 383-6pk
Re: Removing primer overspray on upholstery ? [Re: Crazy73] #314110
05/11/09 01:05 AM
05/11/09 01:05 AM
Red Lion, PA USA
scamper340 Offline
scamper340  Offline
Red Lion, PA USA
I had the same thing happen with one of my fairly new seat covers. Unfortunately, it seems that anything cabable of removing paint/primer from upholstery is also quite capable of removing dye. Maybe you can redye the seat covers after removing the primer.
Re: Removing primer overspray on upholstery ? [Re: scamper340] #314111
05/11/09 09:30 AM
05/11/09 09:30 AM
Crazy73 Offline OP
Crazy73  Offline OP
Maybe I should "overspray" some black onto those droplets?
Pete
Re: Removing primer overspray on upholstery ? [Re: Crazy73] #314112
05/11/09 11:49 AM
05/11/09 11:49 AM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Try some naphtha.
Re: Removing primer overspray on upholstery ? [Re: Crazy73] #314113
05/11/09 12:13 PM
05/11/09 12:13 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I had this happen to me - only the WHOLE interior was covered. Fortunately primer dries quickly and most of it was just a dust. Spray Nine did the job.
Re: Removing primer overspray on upholstery ? [Re: Stanton] #314114
05/11/09 12:59 PM
05/11/09 12:59 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
use a clay bar with a lubricant like water
Re: Removing primer overspray on upholstery ? [Re: Crazy73] #314115
05/11/09 03:05 PM
05/11/09 03:05 PM
BRawls Offline
super gas
BRawls  Offline
super gas
I had the same thing happen on my Road Runner (limelight on a black int.) I used laquer thinner and a fine 'scotchbright' pad and it worked. Make sure you apply some king of dressing to the vinyl after, as this tends to dry it out.
Re: Removing primer overspray on upholstery ? [Re: BRawls] #314116
05/11/09 11:47 PM
05/11/09 11:47 PM
Red Lion, PA USA
scamper340 Offline
scamper340  Offline
Red Lion, PA USA
I wonder what I did wrong, lacquer thinner on a rag took the color right off the cover. I don't think it even touched the primer, boy was I PO'd.
