Dougs D-452 vs Hooker 5209
#3140878
04/26/23 04:16 PM
04/26/23 04:16 PM
Posts: 5,166 CT
GTX MATT
CT
Anyone test D452s against Hooker 5209s on a dyno or track? Curious if the 5209 being equal length is worth anything, and Dougs also doesnt list a primary length for the 452s at all.
Re: Dougs D-452 vs Hooker 5209
[Re: GTX MATT]
#3140896
04/26/23 06:35 PM
04/26/23 06:35 PM
Posts: 10,556 Rittman Ohio
fourgearsavoy
Rittman Ohio
The only thing I can add here is that the Doug's headers PERFECTLY without beating the tubes up. The only thing I had to do was remove the grease fitting from the pitman arm as it was rubbing against the #5 tube. The coating still looks great after 10 years. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#3140959
04/27/23 08:21 AM
04/27/23 08:21 AM
Posts: 5,166 CT
GTX MATT
CT
Thanks for the input! Their coating is alot less than Hookers too.
Are you running straight or angled plug heads?
[Re: GTX MATT]
#3140979
04/27/23 10:14 AM
04/27/23 10:14 AM
Posts: 4,788 Holland MI Ottawa
2boltmain
Holland MI Ottawa
Dougs headers are made of heavier gauge steel than the Hookers. To me that is added quality and value.
Keep old mopars alive.
[Re: 2boltmain]
#3141019
04/27/23 01:17 PM
04/27/23 01:17 PM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
Hooker = made in China
I installed a set of D452's on my '66 Coronet 383 4-speed car. The passenger side header needed some work to clean a Lakewood bellhousing. Also a ding on the driver side to clear the pitman zerk like Gus did.
The last set of Hookers I had go resold.
[Re: Jeremiah]
#3141043
04/27/23 03:41 PM
04/27/23 03:41 PM
Posts: 8,903 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I chose to grind the Lakewood bell rather than hammer the hell out of a coated header !!!
[Re: Stanton]
#3141108
04/27/23 10:16 PM
04/27/23 10:16 PM
Posts: 5,166 CT
GTX MATT
CT
How bad is the interference with the Lakewood?
[Re: Jeremiah]
#3141111
04/27/23 10:51 PM
04/27/23 10:51 PM
Posts: 4,287 Morrow, OH
markz528
Morrow, OH
Maybe but I have 2 not that old sets of 5209s and neither was made in Asia.
