What battery will a group 27 topper fit? #3140716
04/25/23 07:35 PM
04/25/23 07:35 PM
PA
P
PopTop Offline OP
PopTop  Offline OP
P
PA
I was going to buy a reproduction group 27 battery for my completed restoration. Figured that would be easy. Of course, like everything else, they're not currently available. So I thought I'd give this battery topper a shot so at least I'd have something that looks like the original red cap battery. Now I can't find a maintenance free group 27 battery anywhere in order to use this battery topper. All I'm finding is batteries with caps, which won't work with the topper because it needs a flat surface.
Has anyone else had this issue? Any suggestions on where I can find something that will work?
Re: What battery will a group 27 topper fit? [Re: PopTop] #3140722
04/25/23 07:44 PM
04/25/23 07:44 PM
imperial mo.
stickman Offline
stickman  Offline
imperial mo.
I bought a a/c delco 27s battery. It is flat on the top and has the correct length between terminals. Just ordered the topper. Will add mopar sticker on the side. A lot cheaper than a restore battery.
YOU CAN`T RUN WITH THE BIG DOGS IF YOU NEVER LEAVE THE PORCH.
EB5 70 U Code RT/SE Shaker Challenger
Re: What battery will a group 27 topper fit? [Re: stickman] #3140726
04/25/23 08:02 PM
04/25/23 08:02 PM
Philadelphia, PA
GTXKARL Offline
GTXKARL  Offline
Philadelphia, PA
Could you please post some picture . My battery is 8 years old .
Working on cars teaches you patience... and every curse word imaginable.
1970 Plymouth GTX -- A true gentleman's coupe, but a serious muscle machine.
Re: What battery will a group 27 topper fit? [Re: stickman] #3140730
04/25/23 08:20 PM
04/25/23 08:20 PM
PA
P
PopTop Offline OP
PopTop  Offline OP
P
PA
Where did you buy your AC Delco battery? Is there a part number on it?
Re: What battery will a group 27 topper fit? [Re: PopTop] #3140735
04/25/23 08:33 PM
04/25/23 08:33 PM
imperial mo.
stickman Offline
stickman  Offline
imperial mo.
I am a retired auto tech from a GM dealer. It is 88866112 for the part number. 27s . For me it has a 5 year warranty so if it goes bad I remove the topper and get another one.
Re: What battery will a group 27 topper fit? [Re: stickman] #3140737
04/25/23 08:35 PM
04/25/23 08:35 PM
imperial mo.
stickman Offline
stickman  Offline
imperial mo.
Check around auto zone may have them.
Re: What battery will a group 27 topper fit? [Re: stickman] #3140738
04/25/23 08:39 PM
04/25/23 08:39 PM
PA
P
PopTop Offline OP
PopTop  Offline OP
P
PA
Just looked online and it looks like the Auto Zone down the street has one in stock. I'll pick it up tomorrow.
Thanks stickman!
Re: What battery will a group 27 topper fit? [Re: PopTop] #3140739
04/25/23 08:47 PM
04/25/23 08:47 PM
imperial mo.
stickman Offline
stickman  Offline
imperial mo.
Your Welcome. That's what this website is all about helping each other . Post a pic when its in the car.
Re: What battery will a group 27 topper fit? [Re: stickman] #3140749
04/25/23 10:31 PM
04/25/23 10:31 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
On my Group 24, a Duralast battery from AutoZone was the best fit.
The toppers are wider than the '68-'70 B battery hold-downs, though, so you have to either tweak the hold-down or file some clearance on the sides of the topper.
The other benefit of the modern batteries is they don't gas off and create an acidic mess underhood.
It bugs me to not use the correct battery on an original or correctly restored car, but that's better than re-painting the engine compartment.
Re: What battery will a group 27 topper fit? [Re: topside] #3140772
04/26/23 07:10 AM
04/26/23 07:10 AM
imperial mo.
stickman Offline
stickman  Offline
imperial mo.
Year one sells a wider hold down to fit the battery topper. So you don't have to modify one.
Re: What battery will a group 27 topper fit? [Re: stickman] #3140829
04/26/23 11:39 AM
04/26/23 11:39 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
^^^ Thanks for the info, didn't know that !
Re: What battery will a group 27 topper fit? [Re: topside] #3141246
04/28/23 04:21 PM
04/28/23 04:21 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I actually wanted the group 27 with caps.I bought a NAPA group 27 and then I used the push in caps sold on ebay, The toppers make the terminals too short IMO. They seem to fit tight so I hope no leaks.
Re: What battery will a group 27 topper fit? [Re: stickman] #3141610
04/30/23 09:03 PM
04/30/23 09:03 PM
PA
P
PopTop Offline OP
PopTop  Offline OP
P
PA
Installed my AC Delco battery today!
Re: What battery will a group 27 topper fit? [Re: PopTop] #3141845
05/01/23 07:26 PM
05/01/23 07:26 PM
Philadelphia, PA
GTXKARL Offline
GTXKARL  Offline
Philadelphia, PA
thanks for the picture
