no power anywhere
#3140310
04/24/23 09:08 AM
04/24/23 09:08 AM
RapidRobert
73 dart 318. pulled into the garage & heard a slight pop I believe & the car went completely dead. Battery is OK. where should I start for the problem/open? thank you for your time. RR
Re: no power anywhere
[Re: RapidRobert]
#3140313
04/24/23 09:23 AM
04/24/23 09:23 AM
Posts: 12,157 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
The fusible link would be my first thought. But they usually smoke some as they die.
Master, again and still
[Re: DaveRS23]
#3140318
04/24/23 10:10 AM
04/24/23 10:10 AM
RapidRobert
do they just pop for no reason on occaision or is there a strong possibility of a dead short somewhere?
[Re: a12rag]
#3140329
04/24/23 10:28 AM
04/24/23 10:28 AM
RapidRobert
Will do bro, thank you. I was hoping that maybe with the battery being low that it went to full charge voltage & popped it.
[Re: RapidRobert]
#3140391
04/24/23 01:46 PM
04/24/23 01:46 PM
Posts: 10,218 Someplace you aren't
SomeCarGuy
I had a resto voltage regulator pop cruising down the road. Blew some stuff out of the case so I knew that was it. Made a loud sound when it went. Luckily I carry a spare so it was a five minute deal.
I want my fair share
[Re: SomeCarGuy]
#3140395
04/24/23 02:02 PM
04/24/23 02:02 PM
Posts: 6,282 nowhere
Sniper
nowhere
I had a resto voltage regulator pop cruising down the road. Blew some stuff out of the case so I knew that was it. Made a loud sound when it went. Luckily I carry a spare so it was a five minute deal. That wouldn't kill all the power everywhere in the car.
[Re: Sniper]
#3140440
04/24/23 05:52 PM
04/24/23 05:52 PM
Posts: 32,944 Grand Prairie,Texas
stumpy
Grand Prairie,Texas
I had a resto voltage regulator pop cruising down the road. Blew some stuff out of the case so I knew that was it. Made a loud sound when it went. Luckily I carry a spare so it was a five minute deal. That wouldn't kill all the power everywhere in the car. but it could be the cause of the fusible link blowing.
[Re: stumpy]
#3140441
04/24/23 05:59 PM
04/24/23 05:59 PM
Sniper
nowhere
I had a resto voltage regulator pop cruising down the road. Blew some stuff out of the case so I knew that was it. Made a loud sound when it went. Luckily I carry a spare so it was a five minute deal. That wouldn't kill all the power everywhere in the car. but it could be the cause of the fusible link blowing. If it had the poster should have mentioned that and it would not have been a 5 minute fix either. But since it's a fused circuit past the fusible link I would doubt it, generally.
[Re: Sniper]
#3140445
04/24/23 06:24 PM
04/24/23 06:24 PM
Posts: 15,900 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I had a fusible link go for no reason and kill all power. First time it happened left me stranded and scratching my head because everything else checked out good.
Facts are stubborn things.
[Re: RapidRobert]
#3140447
04/24/23 06:29 PM
04/24/23 06:29 PM
Posts: 1,757 Phila
PhillyRag
Phila
73 dart 318. pulled into the garage & heard a slight pop I believe & the car went completely dead. Battery is OK. where should I start for the problem/open? thank you for your time. RR What do you mean "went completely dead"? No cranking, no park/headlights?
[Re: PhillyRag]
#3140469
04/24/23 07:31 PM
04/24/23 07:31 PM
Posts: 20,185 Park Forest, IL
slantzilla
Park Forest, IL
I had that issue on a 73 truck. The fusible link was corroded in half. Where it waz on the fenderwell collected water.
[Re: RapidRobert]
#3140475
04/24/23 08:01 PM
04/24/23 08:01 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
do they just pop for no reason on occaision or is there a strong possibility of a dead short somewhere? After 50 years....yes, they can go with no warning. Have had it happen. Just splice an in line fuse in there and have a handful of 20 amp fuses handy. I had an alternator short out inside and take out my original fusible link last year. To find it, I unplugged all the bulkhead connections and plugged them in one at a time. The in line fuse and several fuses quickly found the culprit. So, sometimes the link finally fails and sometimes something takes it out. IF that is even the problem. But what else can shut down the entire electrical system like that?
[Re: IMGTX]
#3140572
04/25/23 08:53 AM
04/25/23 08:53 AM
Posts: 21,076 Niles , Ohio
therocks
Niles , Ohio
Years ago my 73 Chrysler had problems with the harness under the steering column Seems they liked to burn All power would go out and when played with would come back on.IIRC it wasa problem with them
Chrysler Firepower
[Re: DaveRS23]
#3140696
04/25/23 06:03 PM
04/25/23 06:03 PM
Posts: 1,757 Phila
PhillyRag
Phila
do they just pop for no reason on occaision or is there a strong possibility of a dead short somewhere? After 50 years....yes, they can go with no warning. Have had it happen. Just splice an in line fuse in there and have a handful of 20 amp fuses handy. I had an alternator short out inside and take out my original fusible link last year. To find it, I unplugged all the bulkhead connections and plugged them in one at a time. The in line fuse and several fuses quickly found the culprit. So, sometimes the link finally fails and sometimes something takes it out. IF that is even the problem. But what else can shut down the entire electrical system like that? They should be time-delay fuses to simulate how a fusible link functions.
[Re: PhillyRag]
#3140705
04/25/23 07:00 PM
04/25/23 07:00 PM
Posts: 5,445 So Cal
Sinitro
So Cal
do they just pop for no reason on occaision or is there a strong possibility of a dead short somewhere? After 50 years....yes, they can go with no warning. Have had it happen. Just splice an in line fuse in there and have a handful of 20 amp fuses handy. I had an alternator short out inside and take out my original fusible link last year. To find it, I unplugged all the bulkhead connections and plugged them in one at a time. The in line fuse and several fuses quickly found the culprit. So, sometimes the link finally fails and sometimes something takes it out. IF that is even the problem. But what else can shut down the entire electrical system like that? They should be time-delay fuses to simulate how a fusible link functions. For glass fuses there are some that are slo-blo, and ones that can take a certain % overload before opening... Just my $0.02...
