Possible to test 3 speed wiper switch? #3140246
04/23/23 09:07 PM
04/23/23 09:07 PM
GA
roadrunninMark Offline OP
GA
I got a 3 speed switch, 378, and was wondering how to test it to make sure it works correctly. Anyone have know how to do so? Do you need a 3 speed wiper for testing the switch?
Re: Possible to test 3 speed wiper switch? [Re: roadrunninMark] #3140258
04/23/23 10:01 PM
04/23/23 10:01 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Shop manual wiring diagrams have the info.
Re: Possible to test 3 speed wiper switch? [Re: PhillyRag] #3140269
04/23/23 11:32 PM
04/23/23 11:32 PM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
My Mopar has them for download
NS1AAR
Re: Possible to test 3 speed wiper switch? [Re: roadrunninMark] #3140352
04/24/23 11:14 AM
04/24/23 11:14 AM
central il.
second 70 Offline
second 70  Offline
central il.
Here's a test for an ebody variable speed. Not sure if it's the same but I'm guessing it is. 0 means 0 ohms
Mike
Re: Possible to test 3 speed wiper switch? [Re: second 70] #3140412
04/24/23 03:44 PM
04/24/23 03:44 PM
Canada
E
EW1BH27 Offline
EW1BH27  Offline
E
Canada
AFAIK a "378" is the same as a "380" (variable speed switch). The following is a re-written white paper (PDF) by Slotts of JS Restoratoins .
2770380 Wiper Switch Testing
A = Brown w/ White (Bulkhead Terminal Position 1)
B = Pink
P = Blue (Bulkhead Terminal Position 5)
W = Brown (Bulkhead Terminal Position 19 – Washer Pump Motor)
F1 – Red (Bulkhead Terminal Position 2)
F2 = Green (Bulkhead Terminal Position 6)
B/U = No Connection
B to B/U = B voltage in across the internal circuit breaker.
Always on no matter what speed or off position to B/U. B/U Voltage After Circuit Breaker
The following connections should all be reading 0 ohms, except as noted, when active. Any connection combination not mentioned should not show a reading. The switch body must be grounded from side ground strap to -12v if being tested without the switch panel secured in the dash with all four screws.
In the OFF position:
B to P
A to F2
F1 to Chassis Ground
In On Low through High speed positions:
B to F1 {(0 Low) to (25 High)}
A to F1 {(0 Low) to (25 High)}
B to A
F2 to Chassis Ground
Washer Motor On – No Reading In The Off Position:
B to W
A to W
F1 to W
Re: Possible to test 3 speed wiper switch? [Re: EW1BH27] #3140444
04/24/23 06:16 PM
04/24/23 06:16 PM
GA
GA
Thanks for the info. I will give it a shot.
Found this Youtube video on how to repair a switch (if gummed up with dirty connections). https://www.youtube.com/watch?v=CLm2OkRWV5s
Re: Possible to test 3 speed wiper switch? [Re: roadrunninMark] #3140570
04/25/23 08:40 AM
04/25/23 08:40 AM
Canada
E
EW1BH27 Offline
EW1BH27  Offline
E
Canada
I've had success rebuilding them. That video didn't address the the side terminal that you'll have to unsolder.
Re: Possible to test 3 speed wiper switch? [Re: EW1BH27] #3140593
04/25/23 10:10 AM
04/25/23 10:10 AM
GA
GA
EWB1b - yes, no mention of that, maybe that is the "lug" that he tore. Is unsoldering that one piece straight forward?
Re: Possible to test 3 speed wiper switch? [Re: roadrunninMark] #3140641
04/25/23 01:45 PM
04/25/23 01:45 PM
Canada
E
EW1BH27 Offline
EW1BH27  Offline
E
Canada
Yup very simple. It's the silver piece in the middle of my picture, it's soldered to the outside of the case. I was surprised how little heat it actually took considering the case is a huge heat sink. I thought he broke off one of the tabs (dinks) that had to be straightened out/bent back to open up the switch. Like he said be careful with that, they're pretty soft. I had a tab/(dink) crack as I put it back together. At least it didn't break completely off.
