Spark Plug Heat Range #3139834
04/21/23 09:10 PM
04/21/23 09:10 PM
Cent, OH
Mopar.70 Offline OP
Mopar.70  Offline OP
Cent, OH
So, my recent build is a 500 stroker RB block. Bought it as a .040 over 12.5:1 domed piston motor. For my build I went with a -6 cc dish piston with the Stage 6 heads that should give around 10.5:1 compression. Motor had a Autolite Racing R3933 plugs in it. I'm running 110 fuel, but went with a step up hotter AR3934 plug. Think this is an ok heat range? Or should have stayed with the colder plug?
Re: Spark Plug Heat Range [Re: Mopar.70] #3139847
04/21/23 10:08 PM
04/21/23 10:08 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
what was the reason for going to the hotter plug?
Joe
Without Data, you’re just another guy with an opinion.
Re: Spark Plug Heat Range [Re: Mopar.70] #3139860
04/21/23 11:23 PM
04/21/23 11:23 PM
PA
moparacer Offline
moparacer  Offline
PA
The 3934 is the same as a NGK -8. And I run -8s in a 14:1 motor. You could probably run a 3935 in it at 10.5:1
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Spark Plug Heat Range [Re: moparacer] #3139921
04/22/23 09:48 AM
04/22/23 09:48 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Is there a reason you have to run a non projected tip?
If not the ar3911/10 is the normal projection plug.
ar3933=ar3910
ar3934=ar3911
Re: Spark Plug Heat Range [Re: Mopar.70] #3140024
04/22/23 05:39 PM
04/22/23 05:39 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
I guess I am old school, but read your spark plugs to see if heat range and timing are correct.
Re: Spark Plug Heat Range [Re: jwb123] #3140053
04/22/23 07:48 PM
04/22/23 07:48 PM
Cent, OH
Mopar.70 Offline OP
Mopar.70  Offline OP
Cent, OH
I went with same plug that was in the motor, but a step hotter because I was lower compression. But they may have had these non projected tip plugs in it due to the domed pistons, and maybe I don't need them with flat pistons I have. What's people running in the old stage 6 heads...for those still running them? Motor is together, so be hard to check now I think.
Re: Spark Plug Heat Range [Re: Mopar.70] #3140069
04/22/23 08:59 PM
04/22/23 08:59 PM
Oak Harbor, WA
W
Wicked49670dart Offline
W
Oak Harbor, WA
I run NGK #8 on NA and NGK #10 on nitrous with my stage 6 heads with 12.2 to 1 compression on VP 110!
70 Dart 3400 496 New Best 6.15@110.37 660ft, 9.76@135 with a 1.34 60ft
Re: Spark Plug Heat Range [Re: Wicked49670dart] #3140114
04/23/23 08:52 AM
04/23/23 08:52 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Is it a 5671 or a 5672 (which tip)?
Re: Spark Plug Heat Range [Re: B1MAXX] #3140127
04/23/23 10:20 AM
04/23/23 10:20 AM
Oak Harbor, WA
W
W
Oak Harbor, WA
I use 5671-10, non projected tip! Same with the 5671-8 also!
Re: Spark Plug Heat Range [Re: Mopar.70] #3140194
04/23/23 04:02 PM
04/23/23 04:02 PM
Cab_Burge Online work
Cab_Burge  Online Work
Are your heads aluminum or iron?
Re: Spark Plug Heat Range [Re: Cab_Burge] #3140200
04/23/23 04:54 PM
04/23/23 04:54 PM
Cent, OH
Mopar.70 Offline OP
Mopar.70  Offline OP
Cent, OH
Mine are AL
Re: Spark Plug Heat Range [Re: Mopar.70] #3140255
04/23/23 09:47 PM
04/23/23 09:47 PM
Usually aluminum heads on BB Mopar's act like they've lower the compression ratio one full point and increase the heat needed on the detonation thresholds when compared with the same compression ratio as used in iron headed motor.
My message is BB Mopar usually like a little hotter plug than colder, especially on the street. Colder plugs will be darker, perfect plugs (heat range, ignition timing and dead on air fuel ratios) from a well tuned motor should look like they are almost new.
You need to watch yours and see if they are going black, brown or lite tan under normal light throttle street driving scope
If their dark looking, use the next hotter plug twocents
On your deal I would use NGK # 7 or the Autolite 3923 or maybe the next hotter 3924, Champion RC9YC ( I think, hope luck, that is the correct # for 3/4 reach with the 5/8 body size confused) should work well also scope
Do you know that there is a federal law that can put you in prison for up to 10Yrs for using leaded fuel on the public streets if you are caught and convicted?
That is the main reason I switch to E85 on my race cars and hot street cars work scope up
Re: Spark Plug Heat Range [Re: Cab_Burge] #3140276
04/24/23 12:38 AM
04/24/23 12:38 AM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
Dark, light, brown, black, tan, white. Initially more influenced by air fuel ratio than heat range.
Make an educated guess as to what heat range you may need. (to get close) Dial in fueling, or at least get close.
Then look at jwb123 post, at least in reference to heat range.
Re: Spark Plug Heat Range [Re: B1MAXX] #3140298
04/24/23 08:21 AM
04/24/23 08:21 AM
PA
moparacer Offline
moparacer  Offline
PA
ar3933=ar3910
ar3934=ar3911
I have always used projected on flat top motors and seen some gains vs the non projected. up
