What studs to use on PB master used as manual? #3139828
04/21/23 08:46 PM
04/21/23 08:46 PM
Seattle, WA
3
375inStroke Offline OP
Special needs person
3
Seattle, WA
Manual brake master mounting holes are .343". Power is .354". I want to use the RAYBESTOS MC36406, 15/16" master, but the studs are too small for the holes. What studs do people use?
Re: What studs to use on PB master used as manual? [Re: 375inStroke] #3178898
09/28/23 04:58 AM
09/28/23 04:58 AM
Kansas city, USA
P
paoloweber Offline
paoloweber  Offline
P
Kansas city, USA
While it is unfortunate that the studs on the ​RAYBESTOS MC36406, 15/16" master cylinder may not fit the mounting holes in your manual brake system, there are a few options you can consider.
One option is to find replacement studs that are compatible with your mounting holes. It would be beneficial to consult with automotive forums and communities, such as the ​For A Bodies Only Mopar Forum or the ​For B Bodies Only Classic Mopar Forum, where users discuss their experiences with manual brake conversions and may provide recommendations for suitable replacement studs.
Another option is to explore aftermarket adapter kits specifically designed for retrofitting a manual master cylinder to a power-brake vehicle. These kits often come with the necessary hardware, including studs or bolts, to ensure a proper fit. Researching and reaching out to reputable brake system manufacturers or suppliers may provide you with additional insights and options for finding compatible studs or conversion kits.
Please note that it is crucial to ensure the compatibility of any replacement studs or adapter kits you consider by verifying the specifications and dimensions of your manual brake master cylinder and the mounting holes in your vehicle's firewall.
Remember to exercise caution and consult with experts or professionals in the field to ensure the appropriate installation and compatibility of components for your specific vehicle and brake system needs.
Re: What studs to use on PB master used as manual? [Re: 375inStroke] #3178934
09/28/23 10:10 AM
09/28/23 10:10 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
You are worried about 0.011" diametral clearance difference? If this is the master cylinder you want to use and the holes are too large to suit you, I'd just sleeve the holes and ride off into the sunset.
Raybestos MC36406
Re: What studs to use on PB master used as manual? [Re: paoloweber] #3179121
09/28/23 08:55 PM
09/28/23 08:55 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Geez, who let the spammer in
Re: What studs to use on PB master used as manual? [Re: 6PakBee] #3189098
11/06/23 01:26 PM
11/06/23 01:26 PM
Seattle, WA
3
3
Seattle, WA
Raybestos MC36406
The problem is the heads are round, no hex, like a wheel stud, and they fit loose. Try tightening up a wheel with a spinning wheel stud.
