fiberglass lift off hood #313897
05/10/09 02:29 PM
05/10/09 02:29 PM
USA
74DS Offline OP
74DS  Offline OP
USA
Anyone have advice for how to locate hood pins on a fiberglass lift off hood ??
Thanks Dave
Re: fiberglass lift off hood [Re: 74DS] #313898
05/10/09 04:30 PM
05/10/09 04:30 PM
west palm beach, florida
modelmakerinc Offline
Your question can be interpreted different ways.
If you have mounted pins and want to place the holes in the correct position the best way is to measure in two or three directions
like from the fender edge to the pin center. You can use pieces of tape to give yourself reference points.
Or are you asking where you should mount the pins? or where can you get the pins?
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
Re: fiberglass lift off hood [Re: 74DS] #313899
05/10/09 05:32 PM
05/10/09 05:32 PM
Florida STAYcation
dOOc Offline
The village idiot's idiot
dOOc  Offline
Florida STAYcation
Sooooo many variables ......
Depends on what style of hood it is(does it have a header panel OR severe overhang)... which company made it, what type of bracing is used etc ...
Re: fiberglass lift off hood [Re: dOOc] #313900
05/10/09 06:59 PM
05/10/09 06:59 PM
USA
74DS Offline OP
74DS  Offline OP
USA
I have the pins mounted already , the hood is a Glasstek lift off ... I am trying some tape and string to locate the pins and then transfer to the hood to drill holes ... Will this work ?
Also , what is the best way to drill holes in fiberglass w/o causing any damage ?
Thanks !!
Re: fiberglass lift off hood [Re: 74DS] #313901
05/10/09 07:04 PM
05/10/09 07:04 PM
Florida STAYcation
dOOc Offline
dOOc  Offline
Florida STAYcation
what is the hood for ? ... do you have a pic of the under-side?
Re: fiberglass lift off hood [Re: dOOc] #313902
05/10/09 07:13 PM
05/10/09 07:13 PM
USA
74DS Offline OP
74DS  Offline OP
USA
It is on a 74 dart sport
Re: fiberglass lift off hood [Re: 74DS] #313903
05/10/09 07:15 PM
05/10/09 07:15 PM
Clintwood VA
johnedod Offline
johnedod  Offline
Clintwood VA
Nice car!
Johnedod
68 Road Runner
71 Road Runner
78 Power Wagon
Re: fiberglass lift off hood [Re: 74DS] #313904
05/10/09 07:37 PM
05/10/09 07:37 PM
Florida STAYcation
dOOc Offline
dOOc  Offline
Florida STAYcation
No scoop on the hood ?
A properly braced 69 Cuda/73-6 Dart hood should not need more than FOUR hood pins. UNLESS the car runs some BIG speed and/or has a huge scoop.
I would run the pins on the INSIDE of the bracing .... maybe a foot from the fender edge on the front .... and on the inside of the bracing in the rear ... off the firewall or one of the hood-hinge mounting locations.
Re: fiberglass lift off hood [Re: dOOc] #313905
05/10/09 07:42 PM
05/10/09 07:42 PM
USA
74DS Offline OP
74DS  Offline OP
USA
I have the pins located about 8" from fenders .. How about drilling the holes .. Anyone have any advice ?
Thanks !! Dave
Re: fiberglass lift off hood [Re: 74DS] #313906
05/10/09 07:49 PM
05/10/09 07:49 PM
Florida STAYcation
dOOc Offline
dOOc  Offline
Florida STAYcation
Drilling ? .. use a slooooow drill and DO NOT go through the bracing.
Re: fiberglass lift off hood [Re: dOOc] #313907
05/10/09 07:53 PM
05/10/09 07:53 PM
USA
74DS Offline OP
74DS  Offline OP
USA
Thanks ! I will give it a try .
Re: fiberglass lift off hood [Re: 74DS] #313908
05/10/09 08:31 PM
05/10/09 08:31 PM
Arizona
PolyDart Offline
PolyDart  Offline
Arizona
Yep. Place masking tape over the spot you are drilling through to prevent cracking the gel coat.
I just drilled 10 holes in mine for Dzus fasteners with no problem.
Re: fiberglass lift off hood [Re: 74DS] #313909
05/10/09 08:43 PM
05/10/09 08:43 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Use a heavy tape ...
I like using duct tape.
Once the holes are drilled, position the hood where you want it exactly, rat tail the holes as needed to get there. Once in position put plates on, drill and secure plates.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: fiberglass lift off hood [Re: HealthServices] #313910
05/10/09 09:25 PM
05/10/09 09:25 PM
USA
74DS Offline OP
74DS  Offline OP
USA
Just finished drilling holes ..just have to do some minor "adjustments " to the holes and it will work !
Thanks for the help !!
Re: fiberglass lift off hood [Re: 74DS] #313911
05/11/09 03:34 AM
05/11/09 03:34 AM
Florida STAYcation
dOOc Offline
dOOc  Offline
Florida STAYcation
Minor adjustments ? ... roger that !
With the hood-pin-plates it is muchO more forgiving. NOT like a dzus fastener !!
