idle stop solenoid?
#3138676
04/17/23 10:38 AM
04/17/23 10:38 AM
Posts: 200 Maryland
mrob
Maryland
Hi, Just wondering if any of you use an idle stop solenoid to help with engine run-on (aka dieseling) when you turn off your engine?
Occasionally, I have engine run-on when I turn off the key in Park. I've already lowered the idle speed as low as possible, so don't think there's any more I can do there. I know that I can turn off the engine in gear, but would like to be able to turn off the engine in Park.
Attached is a pic of one option: the Holley idle stop solenoid (P/N 46-74) and the bracket (P/N 20-9). According to Holley, this bracket is designed for 4150/4160 baseplates.
Any comments or suggestions are welcome.
Re: idle stop solenoid?
[Re: mrob]
#3138736
04/17/23 01:23 PM
04/17/23 01:23 PM
Posts: 19,456 north of coder
moparx
if it will adjust up enough, and doesn't interfere with any linkage, i would use that. however, make sure the transfer slot is not exposed. if it is, you will have to make mods to the internals so the transfer slot is not exposed, and the carb will still idle. the only other option may be to drill a small hole in the primary butterfly's, but that would be a last resort. i can't say what mods will be needed, as i know virtually nothing about holley carbs, just carterbrock types. others with much greater knowledge about holley carbs will certainly tell you what to do to solve your problem.
[Re: mrob]
#3138903
04/18/23 04:54 AM
04/18/23 04:54 AM
Guitar Jones
I'd like to know if that solenoid has the power to push the throttle open. I would like to find one that would work for bumping the idle up when the a/c compressor kicks on.
[Re: mrob]
#3138909
04/18/23 07:09 AM
04/18/23 07:09 AM
Posts: 5,444 Indiana
YO7_A66
Indiana
I use the Holley one on my 340. It does not have the power to open the linkage, but it does hold the linkage open once it is extended.
I set mine up for around 850-900rpms in N or P for easy shut down with no dieseling. Then in the drive gears, it idles about 950-1000rpms with the foot on the brake.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: mrob]
#3138974
04/18/23 11:46 AM
04/18/23 11:46 AM
YO7_A66
Indiana
I am using the Holley 20-9 bracket on a QF carb. Since they are both similar, the bracket should mount the same.
When the solenoid/stop is extended, the hex head just needs to hit somewhere solid on your linkage so that it is repeatable.
[Re: Guitar Jones]
#3139125
04/18/23 09:49 PM
04/18/23 09:49 PM
Posts: 1,757 Phila
PhillyRag
Phila
I'd like to know if that solenoid has the power to push the throttle open. I would like to find one that would work for bumping the idle up when the a/c compressor kicks on. Typically you have to give a little pedal-push while key is ON (power to Sol.) to extend the plunger before cranking. None are meant to Push the carb linkage, only to Hold it.
[Re: mrob]
#3139234
04/19/23 11:00 AM
04/19/23 11:00 AM
YO7_A66
Indiana
Good, and the solenoid does not interfere with my 14" drop base air cleaner.
