Information on a mower
#3138831
04/17/23 07:21 PM
04/17/23 07:21 PM
Posts: 5,785 ohio
ruderunner
ohio
We have a White Outdoor riding mower with hydrostatic drive. It's mid or late 90s vintage but still runs and functions great. Want to keep it that way.
I'm wanting to change the oil and filter for the transmission but I'm not having any luck figuring out what oil goes in it. Oddly enough, this seems to be the only thing I can't find anything about for this thing.
Angry white pureblood male
Re: Information on a mower
[Re: ruderunner]
#3138855
04/17/23 08:16 PM
04/17/23 08:16 PM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
' It probably has a Peerless transaxle in it and they do make a kit with a filter and fluid with a fill kit. When I was working on landscape equipment about 38 years ago I used John Deere hydraulic oil in all the hydrostatic drives. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: A12]
#3139086
04/18/23 07:09 PM
04/18/23 07:09 PM
Posts: 5,785 ohio
ruderunner
ohio
Had a chance to investigate a little more. Choosing the right search terms got me the information. They use 20w50 motor oil.
I had forgotten that White was part of MTD and that information helped locate a filter for half the price I've found elsewhere.
Oddly that link didn't work for me earlier today, seems ok now.
[Re: TJP]
#3139155
04/18/23 11:33 PM
04/18/23 11:33 PM
Posts: 21,501 N.E. OHIO, USA
A12
N.E. OHIO, USA
Oddly that link didn't work for me earlier today, seems ok now. regular hydro fluid could have been a costly mistake Not sure if it reads 20w50 motor oil for the transmission but for the rear differential in one of the manuals from the link by TJP? Maybe call a local old MTD dealer and see what they recommend?
[Re: A12]
#3139185
04/19/23 05:47 AM
04/19/23 05:47 AM
Posts: 5,785 ohio
ruderunner
ohio
The manual I found was for my specific model and the instructions and drawings match up with what's in the mower.
The regular gear drive transaxle doesn't have a filter or fan or a fill hose..
My old Ariens had a manual gearbox packed with grease.
[Re: ruderunner]
#3139205
04/19/23 08:36 AM
04/19/23 08:36 AM
Posts: 8,022 Tulsa OK
Bad340fish
Tulsa OK
If you have never changed it you might be better off leaving it alone. I just read a deal from a facebook friend where he changed the hydro fluid in his Kubota tractor that is fairly old. It began to leak from every location it had a seal not to long after that.
68 Barracuda Formula S 340
[Re: Bad340fish]
#3139265
04/19/23 12:16 PM
04/19/23 12:16 PM
Posts: 5,785 ohio
ruderunner
ohio
It's been changed but not for a few years. In my experience, leaks after an oil change are often from changing to synthetic after using dead dinosaurs.
And I'd rather replace seals than a whole transaxle, or realistically a new mower.
[Re: redraptor]
#3139897
04/22/23 07:57 AM
04/22/23 07:57 AM
Posts: 5,785 ohio
ruderunner
ohio
I'm sure Case IH wanted a readily available oil to compensate for how much they leak ☺
