Re: 66 slant 6 engine to 78 slant 6 904 trans, what gives
[Re: cantspel]
#313870
05/10/09 02:44 PM
05/10/09 02:44 PM
RapidRobert
I'm assuming '66 A with modern rod shifter type linkage & the eng is a 66. Ideally you would want a 66(maybe 67?) 904. A custom TC(not practical)or a later(1968 & up) crank into the 66 /6(probably not practical). I do not know about swapping the trans internals. Best would be to find a later /6 in good shape & use the 78 trans/TC. would need to use the 66 pan/pickup/mtr mts/insulators otherwise it drops in.
[Re: cantspel]
#313873
05/10/09 02:59 PM
05/10/09 02:59 PM
Posts: 182 Pennsylvania
cantspel
Pennsylvania
got it, my dacco book shows a 762-S to be what i need, they sent me a 403 which is coarse spline. thanks for the help
[Re: cantspel]
#313874
05/10/09 03:03 PM
05/10/09 03:03 PM
RapidRobert
theres no stock TC that will work on the early /6 crank & the later 904. The trans input spline dia/#'s changed along with the TC hub diameter at the same time.
[Re: RapidRobert]
#313876
05/10/09 03:12 PM
05/10/09 03:12 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
That is why I asked if the crankshaft can't be machined to take the newer converter hub. Just the reversal if installing a pilot bushing for a manual transmission.
[Re: RapidRobert]
#313877
05/10/09 03:13 PM
05/10/09 03:13 PM
Posts: 25,903 Rio Linda, CA
John_Kunkel
Rio Linda, CA
762 is the common rebuilder's number for a '68-up 904 converter used with the /6 and 318, it has the 1.810" pilot hub so it won't work on the pre-'68 crank with a 1.550" register. The 762 "S" might be a special built hybrid with a smaller pilot hub, never seen one but........
[Re: cantspel]
#313879
05/11/09 02:11 AM
05/11/09 02:11 AM
John_Kunkel
Rio Linda, CA
I found and downloaded the Dacco catalog, I didn't know that anybody offered a hybrid but I do now. Great problem solver.
