OD "off" light... #313867
05/10/09 02:09 PM
05/10/09 02:09 PM
Detroit, USA.
MagnumGT Offline OP
MagnumGT  Offline OP
Detroit, USA.
My '97 Van (318)seems to shift the same after third with the light on indicating "OD OFF". Could the light just come on with the switch, without the trans functioning correctly? Any way for the OD to continue to work with the light on? Shifts again just around 45 MPH in drive. Seems like a lot more drop in rpm's than the converter lock-up. Fluid is full and clean.
Re: OD "off" light... [Re: MagnumGT] #313868
05/10/09 03:09 PM
05/10/09 03:09 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
What you may be feeling is the converter locking up not the transmission going into OD.
