Re: Mystery coolant leak -help needed
[Re: Whitey Nocar]
#3138184
04/15/23 12:06 PM
04/15/23 12:06 PM
Posts: 15,887 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Strange because head gasket would normally produce milky substance on dipstick and not darker oil, and exhaust smoke. I'd check my PCV system too although this wouldn't normally produce a leak.
I'd look up top first. So many leaks start at the top and run down and sometimes searching at the top of the engine is forgotten.
Facts are stubborn things.
[Re: Whitey Nocar]
#3138403
04/16/23 11:22 AM
04/16/23 11:22 AM
Posts: 554 Mesa , Az
Jambbii
Mesa , Az
I'd check out the EGR cooler. It's under the intake manifold and has some coolant lines running to it. From my research (I was looking to possibly delete it) it seems that these can leak an be a pain to spot.
70 Challenger 1960 Town Wagon P Pump 24v cummins project 06 Mega 3500 Drw 2wd 12 Durango R/T 18 Power Wagon 67 A100
[Re: Jambbii]
#3138603
04/16/23 10:50 PM
04/16/23 10:50 PM
Posts: 6,562 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
I'd check out the EGR cooler. It's under the intake manifold and has some coolant lines running to it. From my research (I was looking to possibly delete it) it seems that these can leak an be a pain to spot. Gas engine with an EGR cooler? Kevin
[Re: Whitey Nocar]
#3139241
04/19/23 11:20 AM
04/19/23 11:20 AM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Thanks for the advise everyone. I looked again and the thing is still dripping. The main drips coming from the crank pulley area, which made me think possible water pump issue, but looks dry around water pump… at least the parts I can see.
I think this is going to the dealership, and I’m gonna see if they honor the Lifetime warranty I paid for. I expect they will if it’s a water pump or get cooler.
I will report back It can be really difficult to see the weep hole area. See if there's any wobble to the water pump pulley. A lot of time there be a wobble to the pulley about the time they start leaking.
