Damper weights, which ones which? #3137322
04/12/23 09:47 AM
04/12/23 09:47 AM
Minn
SportF Offline OP
SportF  Offline OP
Minn
I need a damper for my cast crank 440, and I've had this one for years. No directions in the box, a Pro performance 540 HD. So, is neutral with no weights, thin weight for 6 pak, and thick for cast? Anybody dealt with this. I bought this years ago thinking it was a DCC from Mopar, but now I think not.
Re: Damper weights, which ones which? [Re: SportF] #3137330
04/12/23 10:40 AM
04/12/23 10:40 AM
CrazyD Offline
CrazyD  Offline
Do these instructions and part numbers match what you have?
Attached PDF document
Re: Damper weights, which ones which? [Re: CrazyD] #3137334
04/12/23 10:54 AM
04/12/23 10:54 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
That's not exactly correct. The 1970 HP 440 is also a heavy rod, steel crank, externally balanced engine.
Re: Damper weights, which ones which? [Re: CrazyD] #3137345
04/12/23 11:39 AM
04/12/23 11:39 AM
Minn
SportF Offline OP
SportF  Offline OP
Minn
No part numbers on the weights. This is Pro Performance, but those instructions certainly suggest what I think. Thank you much for digging that up. I would also guess that a company may make many dampers and put different names on them, an that may be what happened here.
I've had this thing since 2018, just never really looked at it. The stock damper I have now is wobbling, so its going to find a home.
Re: Damper weights, which ones which? [Re: SportF] #3137349
04/12/23 12:21 PM
04/12/23 12:21 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I JUST installed one of those. They were sold by a member on here a number of years ago and they didn't come with any instructions. I remember posting the same question so an old search might turn up the answer but those instructions someone posted appear to be what I was told.
Worth noting is that the timing marks are not "etched" they're printed with some cheapo ink. If you wipe the damper with thinners they'll disappear! Since the thing is also bare metal and prone to rusting, I clearcoated mine - which smeared the timing marks but they're still good enough.
Re: Damper weights, which ones which? [Re: Stanton] #3137464
04/12/23 05:54 PM
04/12/23 05:54 PM
Minn
SportF Offline OP
SportF  Offline OP
Minn
thanks for that info!!
