Bolt-on IRS #3136998
04/10/23 05:29 PM
04/10/23 05:29 PM
NotRussia
2
2fast4yourBrain Offline OP
Whack top Dodger
Whack top Dodger
2
NotRussia
https://www.heidts.com/part/irc-810...-1970-1974-dodge-challenger-and-cuda-irs
Maybe bolt-on, but after bolting it on and checking pinion angle (and centering in wheel well), probably better to weld on that frame cover/support:
Re: Bolt-on IRS [Re: 2fast4yourBrain] #3137083
04/11/23 01:17 AM
04/11/23 01:17 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Are those hubs welded steel? eek
Kinda of takes away a lot of the advantages a removal carrier.
In the pic, it looks well thought out and robust except for maybe the upper coil over mounts.
is that the design they have had for the past few years or something new?
Is it priced yet? Yes it is $9734
Re: Bolt-on IRS [Re: jcc] #3137148
04/11/23 11:48 AM
04/11/23 11:48 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Careful with the “stock” track width
Clip——-incorrect info———clip
This is the setup Troy is working with for a 68-70 Plymouth B-body application. Some redesigning for width and wheelbase.
Re: Bolt-on IRS [Re: autoxcuda] #3137199
04/11/23 03:31 PM
04/11/23 03:31 PM
NotRussia
2
Whack top Dodger
Whack top Dodger
2
NotRussia
61 1/2” is NOT stock E-body track width
https://www.reillymotorsports.com/70-74-e-body-8-3-4-housing-and-axle-package-for-street-lynx.html
61-3/4" wheel-to-wheel measurement using Wilwood or Baer disc brakes.
https://www.forabodiesonly.com/mopar/threads/an-accurate-8-3-4-rear-axle-width-list.365494/
E-BODY
'70-'74= 61 5/8"
Pretty close if you ask me.
Re: Bolt-on IRS [Re: 2fast4yourBrain] #3137205
04/11/23 04:04 PM
04/11/23 04:04 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
E-BODY
'70-'74= 61 5/8"
You’re right in the E-body. I was looking at the Flange to Flange measurement on that chart
Thier B-body was too wide for 68-70 and it’s in process.
