Re: Steel Billet or Aluminum main caps for street/strip motor
[Re: Stanton]
#3137046
04/10/23 09:37 PM
04/10/23 09:37 PM
Posts: 20,195 PA.
pittsburghracer
"Little"John
"Little"John
PA.
The only stock 440 block I ever cracked had 440source steel caps on.
[Re: pittsburghracer]
#3137047
04/10/23 09:46 PM
04/10/23 09:46 PM
Posts: 10,043 MN
JERICOGTX
MN
Not sure why you’d have to service the bearings more than usual with aluminum main caps? Some manufacturers use iron blocks with aluminum mains. Cadillac did this IIRC.
69 GTX
68 Road Runner
[Re: Stanton]
#3137056
04/10/23 10:12 PM
04/10/23 10:12 PM
Posts: 2,005 Apollo, PA.
B1MAXX
Apollo, PA.
I don't think 600 HP warrants anything other than stock caps. Just my opinion. x2
[Re: GTXMEX]
#3137067
04/10/23 10:53 PM
04/10/23 10:53 PM
Posts: 20,195 PA.
pittsburghracer
"Little"John
"Little"John
PA.
OK. But if I don't have the factory main caps and only steel billet or Aluminum appear to be available new, what do I go with? You can’t go wrong with aluminum. Monte recommended that to everyone on this site years ago while he was living.
[Re: GTXMEX]
#3137068
04/10/23 10:56 PM
04/10/23 10:56 PM
Posts: 43,269 Bend,OR USA
Cab_Burge
If your going to replace them don't use steel The harmonics from cap walk will crack the main webbing and you won't know it until that block fails Aluminum caps don't do that is what I have seen so far Your better bet is to find a good race block or a good 400 block withe thicker main webbing and build it with good caps and so on, they tak ea lot more power and punishment than any stock 440 production car block made to date
[Re: GTXMEX]
#3137434
04/12/23 04:03 PM
04/12/23 04:03 PM
Posts: 13,380 Marion, South Carolina [><]
an8sec70cuda
At 600 hp, the stock caps will be fine. If I were going through the expense of installing new caps, they'd be aluminum.
[Re: B1MAXX]
#3137596
04/13/23 02:10 AM
04/13/23 02:10 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
I don't think 600 HP warrants anything other than stock caps. Just my opinion. x2 x3 (with ARP studs)
[Re: 451Mopar]
#3137599
04/13/23 02:37 AM
04/13/23 02:37 AM
Posts: 494 IL
EchoSixMike
IL
If you get the tune wrong, especially with nitrous, no main caps are going to help you. Aluminum caps help dampen vibrations and reduce/prevent fretting and windmilling. Magnesium would be even better, but then you'd have a corrosion issue in that environment. S/F....Ken M
[Re: EchoSixMike]
#3137604
04/13/23 03:39 AM
04/13/23 03:39 AM
Cab_Burge
If you get the tune wrong, especially with nitrous, no main caps are going to help you. Aluminum caps help dampen vibrations and reduce/prevent fretting and windmilling. Magnesium would be even better, but then you'd have a corrosion issue in that environment. S/F....Ken M Dang ,dude I hope that didn't hurt you or the car
