ZF 8-speed swaps. Next big thing? #3136019
04/06/23 06:39 PM
04/06/23 06:39 PM
Nor here, Nor there
Dart 500 Online content OP
Dart 500  Online Content OP
Nor here, Nor there
Re: ZF 8-speed swaps. Next big thing? [Re: Dart 500] #3136377
04/08/23 05:50 AM
04/08/23 05:50 AM
Brisvegas, Australia
Alchemi Offline
Alchemi  Offline
Not exactly the only thing changed.... Clogged injectors and a sloppy rear end later..
Zip ties for the flex lines...
Nice that they have the electronics working on the box.
Now we just have to stop all the chev ppl taking all the dodge boxes.... They are in bmws too ffs
Re: ZF 8-speed swaps. Next big thing? [Re: Alchemi] #3136426
04/08/23 10:15 AM
04/08/23 10:15 AM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
Sure they are in BMW's, ZF8 first use was in a bmw 7 series. ZF and BMW are both German. Trans doesn't even need to take a boat ride to end up in their cars smile
Re: ZF 8-speed swaps. Next big thing? [Re: Alchemi] #3136429
04/08/23 10:21 AM
04/08/23 10:21 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
they are in several vehicles but the bell housing is different. There is a post here somewhere where a guy made one to go on a 440(lot of machine work). Hopefully somebody will come up with a adapter/s to go on MOPAR ENGINE (other than a hellcat).
Re: ZF 8-speed swaps. Next big thing? [Re: Moparite] #3136498
04/08/23 02:09 PM
04/08/23 02:09 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
They should bolt right up to a small block, it would need some kind of flex plate adapter but the small block shares the same bellhousing pattern as the G3 hemi does. There might be issues with the starter mounting though I don't know.
68 Barracuda Formula S 340
Re: ZF 8-speed swaps. Next big thing? [Re: Bad340fish] #3136555
04/08/23 05:52 PM
04/08/23 05:52 PM
Nor here, Nor there
Nor here, Nor there
Pretty sure the ZF90 (hellcat) version was first designed to be used on those twin turbo V12 6500lb Rolls Royces and Bentleys. If those weren't on the shelf the hellcat probably wouldn't have been able to happen
Re: ZF 8-speed swaps. Next big thing? [Re: Dart 500] #3136642
04/09/23 02:15 AM
04/09/23 02:15 AM
Cab_Burge Online work
Cab_Burge  Online Work
Are those tranny suppose to be good for some drag and heavy street with 700+ HP motors?
Re: ZF 8-speed swaps. Next big thing? [Re: Cab_Burge] #3136689
04/09/23 11:02 AM
04/09/23 11:02 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
Re: ZF 8-speed swaps. Next big thing? [Re: Cab_Burge] #3136711
04/09/23 12:08 PM
04/09/23 12:08 PM
Deep DEEP SOUTH
LAD 524 Offline
LAD 524  Offline
Deep DEEP SOUTH
Lots of supercharged 800-1000+ HP Hemis running FAST in heavy late model Dodge muscle cars and Jeep SRT 4WDs at 4500lbs.
Usually,past 800 WHP in heavy cars the trans needs a few mods, lots of 8 spd specialists around building them. They still use the OEM style torque management between shifts. I imagine this could be achieved with a programmable timing control unit to pull timing between shifts.
The software/electronics for the swap now exists and are sorted; adapters are available to allow it to bolt up to a BBM. If you have a modded trans tunnel and eliminated the torsion bars with a coil overs as I have the swap is way easier, but many are'nt willing to do that to their rides so that is the deal killer.
I've seen converters to 4500 rpm stall but if required, I have'nt seen anything with more stall available as yet.
I'm looking into possibly going down this path in the future. Changing out the gears in the Dana in my car to 3.23s with a 30" tire would be work and it'll be closer to a Hellcat's 3.07 rear gear option with the tire OD. With a 4.71 first gear you'll be ripping through the gears like a Hellcat hence the low number final drive ratio with a double OD in 7th and 8th to boot.
Info from the Hellcat forum:
1st -- 4.714
2nd -- 3.143
3rd -- 2.106
4th -- 1.667
5th -- 1.285
6th -- 1.000
7th -- 0.839
8th -- 0.667
Hellcat 2.62 final drive
( 1st x Final drive )
4.714 x 2.62 = 12.35068 SLR
(2nd gear x Final Drive )
3.143 x 2.62 = 8.23466
Old NAG1
( 1st x Final )
3.588 x 3.06 = 10.97928
727/904 with various gear ratios
( 1st x final drive )
2.45 x 4.10 = 10.045
2.45 x 4.56 = 11.172 ( Close to NAG1 )
2.45 x 4.88 = 11.956
4.88s and still not there yet SLR wise.
2.45 x 5.13 final drive = 12.5685
Hellcat vs Old School
To compare a 1st gear start - Your final drive ratio would be around 5.04 with a 28" tire
To compare a 2nd gear start - Your final drive ratio would be around 3.36 with a 28" tire
To complete the swap, you'd have to use an OEM style Hellcat shifter, aftermarket shifter handles are available to make it look like an aftermarket 3 spd shifter.
I think it would be awesome if I could get the appropriate converter sorted out.
Lots to consider, it ain't a straightforward swap but it can be done.
Re: ZF 8-speed swaps. Next big thing? [Re: LAD 524] #3137064
04/10/23 10:43 PM
04/10/23 10:43 PM
racine,wi
70gtx1 Offline
70gtx1  Offline
racine,wi
Thats pretty cool for sure. Problem is too many will believe their car would be that much faster by simply swapping in an 8 speed. Some combos will benefit , and some wont make much a difference at all. To many variables. I know of a guy who swapped out a 46re to an 8 speed and gained a little over a.15 in the 1/4 in his hemi powered Dakota. Its an awesome trans though for sure.
Re: ZF 8-speed swaps. Next big thing? [Re: 70gtx1] #3137093
04/11/23 04:43 AM
04/11/23 04:43 AM
Nor here, Nor there
Nor here, Nor there
Over the NAG1 it was said the biggest gains were from 2nd to 5th with the ZF, and thats over a 5-speed. Could be pretty big over 3 spd, or a glide.
Re: ZF 8-speed swaps. Next big thing? [Re: Dart 500] #3137303
04/12/23 08:04 AM
04/12/23 08:04 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
The advertising that the 8 speed is 98% efficient in every gear is amazing to me, especially the high ratio 1st and 2nd gears
Re: ZF 8-speed swaps. Next big thing? [Re: 360view] #3137323
04/12/23 09:54 AM
04/12/23 09:54 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
That does sound outrageous but if you have ever driven a vehicle with these trans they work soooo well. We have had a Durango R/T and a Grand Cherokee with the 8 speed. I like to leave the little indicator on the dash that shows you what gear it is in, its interesting the choices it makes. When in "sport mode" they shift firm and quick, in regular mode you seldom even notice. FWIW my wife's Grand Cherokee picks up a tenth in sport mode lol.
Re: ZF 8-speed swaps. Next big thing? [Re: Dart 500] #3137677
04/13/23 10:37 AM
04/13/23 10:37 AM
It's Complicated
HDNMOPERS Offline
HDNMOPERS  Offline
It's Complicated
JVX transmissions has the adapter ready for the SB and BB Sound German Automotive has the controller
Re: ZF 8-speed swaps. Next big thing? [Re: HDNMOPERS] #3138740
04/17/23 01:39 PM
04/17/23 01:39 PM
moparx Offline
moparx  Offline
how much tunnel work is required for this swap where a 727 lives now ?
beer
Re: ZF 8-speed swaps. Next big thing? [Re: moparx] #3138825
04/17/23 06:54 PM
04/17/23 06:54 PM
rust belt
Moparite Offline
Moparite  Offline
rust belt
Quote
Show me where it says anything about the ZF8.
link
Re: ZF 8-speed swaps. Next big thing? [Re: Moparite] #3139428
04/20/23 08:12 AM
04/20/23 08:12 AM
It's Complicated
HDNMOPERS Offline
HDNMOPERS  Offline
It's Complicated
Call John Vinson @JVX 901-274-7248 he just starting making these they are not listed on his site. John is semi retired and while he and I were talking about a 727 he was building for me. I asked about doing a 8HP70 adapter he said if there was interest he could do it. So I put the word out and he got enough interest and he's doing them now. He has BB and SB kit. Russell Drake at Sound German Automotive can help with the controller. I have my adapter kit but not ready to start the conversion yet. There are some SB LA conversions done I have heard. Go on facebook page LA-B/RB Engines to 8hp70-90-NAG1. There is more info there.
Re: ZF 8-speed swaps. Next big thing? [Re: HDNMOPERS] #3139439
04/20/23 09:12 AM
04/20/23 09:12 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
What is the first and second gear ratios in theat transmission? I remember reading that the 8 speed in my 2014 truck had lower first and second gears ratios than the first gear in the previously used 6 speed. It would be pretty cool to go from a 4.10 to a 3.55 and keep the SLR in the same range, then have the OD to boot.
Re: ZF 8-speed swaps. Next big thing? [Re: justinp61] #3139448
04/20/23 09:30 AM
04/20/23 09:30 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
1st is 4.71.
See LAD 524's post above for the rest.
Kevin
Re: ZF 8-speed swaps. Next big thing? [Re: Cab_Burge] #3139485
04/20/23 11:54 AM
04/20/23 11:54 AM
It's Complicated
HDNMOPERS Offline
HDNMOPERS  Offline
It's Complicated
There is quite a bit to this conversion. Adapter kit TCM and Harness and HP tuner and s TPS if you running carburetor. Has for HP/TQ there are 900-1000 HP cars using HP70. More HP than that probably better to do the HP90. My deal is a 512 with 640HP/670TQ so I'm good. Russell Drake at Sound German Automotive can help with everything you need to do this. He's got stock shifters paddle shifters TCM harness and remote tuning ability. Also on my deal I gonna have to send my HP70 TCM in to Russell to program the trans itself. I'm gonna do mine with a 1320 calibration. So I will have 3 modes the Track mode=Trans Brake Sport= Manual shift and Street mode= Full auto. So I'm gonna need the paddle shifter plus a stock shifter and mode selector. I will confirm all this with Russell and make sure I'm telling this right. I will let you guys know
UPDATE Talked with Russell. Everything above is doable. But he said I could hold off on the TB. I can always upgrade to the TB feature later. He says TB works well but didn't know if it wouldn't be just as good without for what I'm doing. So I'm leaning now more to just to all time Track mode without the TB.
