Anybody Convert to Petronics? #313507
05/10/09 01:38 AM
05/10/09 01:38 AM
The Dalles, OR.
Dusted_Ya Offline OP
The Dalles, OR.
Thinking about changing over to petronics distributor. Do I still need a ballast resistor? Likes? Dislikes?
Re: Anybody Convert to Petronics? [Re: Dusted_Ya] #313508
05/10/09 01:41 AM
05/10/09 01:41 AM
Walnut Creek, CA
blown340 Offline
blown340  Offline
Walnut Creek, CA
I haven't used their full distributor, but I have used their electronic ignition kit for the factory points distributor on multiple 318's and it has worked great and been in service for years now with no issues.
-Jon
70 challenger convertible. 340/5 speed. blown, intercooled, efi, blah blah blah 71 valiant scamp 318/A833OD/AC/PS 00 dakota RC 4.7L 5 spd autoX'r. SRT10/T56 swap in process 73 W200 Power wagon, PTO winch, 4 spd
Re: Anybody Convert to Petronics? [Re: blown340] #313509
05/10/09 01:48 AM
05/10/09 01:48 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
The conversion kits worked awesome last time I used one, and I have had several.
I saw that the new ones have a multispark deal as well.
I didn't ever have any problems. Easy to install but you may have to ream the hole so the extra wire will fit.
Be CERTAIN you have a steady 12 volts. Be damn certain. I had one that worked great but crappy out when hot. Figured out that the voltage dropped when things got hot under the hood. Fixed that and it ran great.
I want my fair share
Re: Anybody Convert to Petronics? [Re: SomeCarGuy] #313510
05/10/09 05:38 AM
05/10/09 05:38 AM
MA
440beeper Offline
440beeper  Offline
MA
I used their conversion kit (they hadn't started selling their distributors yet) on my Dad's Chevy. Super easy install and has been working great for years.
Re: Anybody Convert to Petronics? [Re: 440beeper] #313511
05/10/09 11:56 AM
05/10/09 11:56 AM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
I have a plug and play Pertronix billet on my 440.. My old distributor was worn out and so my options were open. Only negative was I had to grind on my head a little as the base of the distributor was to wide to fit.. I went with the black cap with the female ends to look somewhat stock, but you can use a red cap with the male ends. I like the idea of a bearing inside the distributor instead of a bushing.. Clean, simple and it works great....
Someone was having a closeout ( bouchillon??) on the MSD plug and plays.. $99 I think?? a steal...
Re: Anybody Convert to Petronics? [Re: Dusted_Ya] #313512
05/10/09 06:47 PM
05/10/09 06:47 PM
Andrewh Offline
Andrewh  Offline
I have used it on two cars. You still need the ballast unless you get a new coil that runs on 12 volts.
Re: Anybody Convert to Pertronix? [Re: Andrewh] #313513
05/11/09 11:57 AM
05/11/09 11:57 AM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Use a 12 volt coil with a built-in ballast, like the Pertronix Flamethrower and you can bypass or remove the original ballast resistor.
Re: Anybody Convert to Pertronix? [Re: Snoopy] #313514
05/11/09 11:59 AM
05/11/09 11:59 AM
Snowing in the north!
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
I have the new Ignitor II and it removes the
ballast all together. Nice setup and works quite
a bit better than the original.
Re: Anybody Convert to Pertronix? [Re: Dart 340] #313515
05/11/09 12:08 PM
05/11/09 12:08 PM
scratchnfotraction Offline
over 9 yrs now...not a single prob
exept I swaped to another rotor,which does not fit it very good
swaped back to the pertronix one,then picked up a new pertronix one at a swap meet
got the points conversion with the 40,000 volt flame thrower coil
i will be trying the plug and play dist and flame ignitor II coil next
Re: Anybody Convert to Pertronix? [Re: scratchnfotraction] #313516
05/11/09 01:51 PM
05/11/09 01:51 PM
NE Ohio
71 FJ6 Charger Offline
NE Ohio
best thing since sliced bread!
'71 383HP FJ6 Charger SE
Re: Anybody Convert to Petronics? [Re: Dusted_Ya] #313517
05/11/09 06:26 PM
05/11/09 06:26 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Robert,
I "dumped" at lot of Pertronix info last night in the thread "Changing 69 R/T to elect. ignition",....located here in the Q&A section,.....
Mike
Re: Anybody Convert to Petronics? [Re: Dusted_Ya] #313518
05/11/09 07:15 PM
05/11/09 07:15 PM
rochester michigan, oakland co...
drmonday Offline
drmonday  Offline
Have one on my coronet R/T. Same as everybody else,easy to install. Works fantastic! Great product!
Re: Anybody Convert to Petronics? [Re: drmonday] #313519
05/12/09 09:08 AM
05/12/09 09:08 AM
Dallas, Wisconsin
BurntOrange Offline
BurntOrange  Offline
Dallas, Wisconsin
I'm waiting for the Ignitor III billet distributor.
Not available yet. MSD performance w/rev limiter all in the "dis." And you can use either their 60kv or 45kv coil.
I've used the original conversion in 2 cars and they've worked well.
Re: Anybody Convert to Petronics? [Re: Dusted_Ya] #313520
05/12/09 02:00 PM
05/12/09 02:00 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
I have their distributor and rev limiter (bought it before the III version came out) on my 440 in the 66 Coronet. I checked the advance curve against Eburgs recommended curve in the Mopar Action tech section and it was right on, didn't need to change a thing. My fuel economy went up a bit, and a tad more seat of the pants dyno HP increase.
You don't need a ballast resistor if you use the right coil with the correct resistance/impedance. I used their 60KV Ecore coil with a bracket I fabricated to use the stock coil bolt holes.
I did have to clearance the cylinder head quite a bit
Coil is in front of the air filter, rev limiter is next to the voltage regulator on the fire wall.
