Re: Lowering IAT with a roots
[Re: Dragula]
#3134001
03/31/23 06:00 PM
03/31/23 06:00 PM
Posts: 12,588 Great Neck,LI,new york
hemi-itis
I can just imagine how much the dual quad set up costs And I do need new rear tires and my helmut is out of date. It's always something!
[Re: an8sec70cuda]
#3134754
04/03/23 01:31 PM
04/03/23 01:31 PM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
I've never had a blown combo, but from what I've seen others go through...I'd absolutely go E-85. I have to agree. It's a shame it is not readily available for you. I added the the smallest single enderle nozzle I could find spraying E85 in my charge pipe pre-throttle and dropped my IAT ~50 degrees. I was seeing 370F out of the compressor into the intercooler and 180F out of the intercooler. With the nozzle, IAT was ~130F. After going from nitrous to turbo, I never want to bother with filling bottles, and messing with bottle heaters again.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: OUTLAWD]
#3134851
04/03/23 06:45 PM
04/03/23 06:45 PM
hemi-itis
Thanks to all that replied. I can see that E is the way to. I would need to get a 16 gallon fuel tank and not sure if the steel braided hose I have i ok for E. Now have a magna 500,is that E compatible?? Then send the SV1's in to change. Just NOT in the budget this year so I'm stuck in the low to mid nines.
[Re: hemi-itis]
#3134908
04/03/23 09:14 PM
04/03/23 09:14 PM
Posts: 713 Lake Villa Il
INTMD8
Lake Villa Il
I don't know about the fuel pump but you want teflon/ptfe fuel line for E85. You could always order some drums of Ethanol and mix your own.
[Re: racerx]
#3135021
04/04/23 10:58 AM
04/04/23 10:58 AM
hemi-itis
I hear you guys on the hassel of refilling the bottles.I have 2 local friends with mother bottles and filling pumps. The reality is I would only need the juice at the track which is a rare occation for me these days.It's a long haul to a track so it must be a 2 day affair so.......... Street dring on pump gas is still 750 to 800 HP,I just want to run that elusive 8 second pass! One of these daze I will switch to E
[Re: hemi-itis]
#3136022
04/06/23 07:01 PM
04/06/23 07:01 PM
hemi-itis
Spoke with Rodney at Pro Meth for a system to fit my need.Sent some picture's so he could see what I have. My question to you guys is which will work better,,,,,water/meth or E85.I figure the cost for either should be about the same, What say you?
