Max boost for a Hellcat crate Engine #3101004
12/09/22 11:54 PM
12/09/22 11:54 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
What is the max boost a Hellcrate will tolerate over the long haul...
Re: Max boost for a Hellcat crate Engine [Re: Dragula] #3134794
04/03/23 02:48 PM
04/03/23 02:48 PM
Dragula Offline OP
Dragula  Offline OP
You guys are the Tech damit....
Re: Max boost for a Hellcat crate Engine [Re: Dragula] #3134810
04/03/23 03:28 PM
04/03/23 03:28 PM
Nor here, Nor there
Dart 500 Offline
Dart 500  Offline
Nor here, Nor there
Is that just a stock hellcat crate engine? I'd go talk with the hellcat guys and see what boost they're running. I know there is a super simple way to get another 150hp out of them, all depends what you want to do
Re: Max boost for a Hellcat crate Engine [Re: Dart 500] #3136227
04/07/23 01:26 PM
04/07/23 01:26 PM
racine,wi
70gtx1 Offline
70gtx1  Offline
racine,wi
From what Ive personally seen, guys that run into trouble are running the 10 percent lower pully, and the smallest upper pulley you can get. Know a few guys that had their blowers explode from being spun to fast with that combo. Once you get around 16 psi, fuel starts to be an issue, and you have to consider e 85.
Re: Max boost for a Hellcat crate Engine [Re: Dragula] #3136985
04/10/23 03:00 PM
04/10/23 03:00 PM
Bowling Green, KY
BlakDak71 Offline
BlakDak71  Offline
Bowling Green, KY
I ran a 2.79 upper pulley (17-18psi) on mine on 93 for a couple years with no issues. I switched it to E85 and ran the hell out of it for a couple years before eventually breaking two piston ring lands. Trapped 140mph with a 6 speed at 4000lbs race weight though lol
