Installing clutch then storing motor #3134267
04/01/23 07:34 PM
04/01/23 07:34 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
A number of years ago I built my motor and installed the clutch and PP then covered the motor up and left it for a couple years. At some point I pulled the bell off as well as the clutch and noticed where the metal particles are in the disk it had formed rust spots on both the flywheel and PP. The motor has been stored in a VERY dry environment so I don't suspect humidity or moisture being the issue. Anyhow., I'm now about two months away from installing it in the car BUT it likely won't be on the road till the summer of '24. So basically my question is: has anyone else experienced this problem with long term storage? Its a Centerforce dual-friction assembly.
Re: Installing clutch then storing motor [Re: Stanton] #3134271
04/01/23 07:49 PM
04/01/23 07:49 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Many times. Some sort of moisture got in there. Pretty hard to stop that unless you are is a controlled atmosphere. I would just sand it off.
Re: Installing clutch then storing motor [Re: Stanton] #3134468
04/02/23 02:48 PM
04/02/23 02:48 PM
AndyF Offline
AndyF  Offline
My old clutch would "weld" itself to the flywheel over the winter when stored in the garage. The new clutch doesn't seem as prone to doing that.
Re: Installing clutch then storing motor [Re: Stanton] #3134485
04/02/23 04:06 PM
04/02/23 04:06 PM
I've seen front disc brake pads do that, stick to the rotors, on cars that sit a long time between being driven shruggy
Re: Installing clutch then storing motor [Re: Cab_Burge] #3134493
04/02/23 04:26 PM
04/02/23 04:26 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
^^^ Yup, discs and drums will do that if they sit long enough in the wrong environment, as well as clutches.
Since the engine's out, should be easy to pull the PP & clutch and clean everything up.
Re: Installing clutch then storing motor [Re: Stanton] #3134496
04/02/23 04:32 PM
04/02/23 04:32 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
It's a form of Mechanical Welding that occurs. Metal pressed together under certain pressure.
Re: Installing clutch then storing motor [Re: PhillyRag] #3134538
04/02/23 06:25 PM
04/02/23 06:25 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Quote
This isn't the issue I'm facing. I already did that a few years back and left the clutch off. Now I'm in the process of assembling everything to go back in the car. BUT its still going to be sitting for the better part of a year while the whole thing goes back together.
Anyhow, I was more curious if it was a common issue. I'm well aware of what brake pads and rotors do - my wife's bitching about it all the time on her car !
