1976 D series Question #3133992
03/31/23 05:09 PM
03/31/23 05:09 PM
Bennett, Colorado
Charger69RT8 Offline OP
Bennett, Colorado
Does anybody have the track width information for the D100's? My internet searches have come up empty. This is related to my Dakota post question. I am contemplating putting that 9 1/4" from a Dakota under my pickup noted in the title. I believe it to be little wider than the 8 1/4 in it, but wonder how it compares to the front track width. Getting accurate measurements has not happened yet. Prelim measure has the spring perches very close to the same.
2012 Challenger SRT
2012 Charger SXT AWD
69 Charger R/T
78 Chrysler New Yorker 440CI
89 Dodge Daytona ES 2.5L Turbo
99 Ram 2500 4X4 5.9L6
Re: 1976 D series Question [Re: Charger69RT8] #3134021
03/31/23 07:31 PM
03/31/23 07:31 PM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
The square body Dakota (88-96) track width is more narrow then a full sized pickup of the same era by about 6". The rear axle itself was what made the 88-96 Dakota more narrow and the 1" -2" wheel offset made it more pronounced). The early 8 1/4 Dakota axle failed from a healthy small block, so back then several guys put a full sized pickup axle under the Dakotas and the rear tires were at the outer edge of the Dakota bed sides using the Dakota wheels. The front wheel tracking on most trucks pretty much matches the rear tracking width. Wheel mounting surfaces on an 88-96 Dakota front disc was really close to 60" wide, full sized trucks were about 66" wide.
The 6 bolt Dakota axles were about the same width as the older versions, but listed a slightly wider track width. Most of that was because of the 6 bolt wheel offset placed the wheel centers closer to the back side of the wheel rim (very close to being centered). The early Dakota wheels had the wheel center closer to the outside of the wheel rim (more rim behind the center).
Depending on which 9 1/4 rear you have, it could be the older 6 bolt wheels, or the more modern Dakota 5 bolt wheels that I believe have a different bolt pattern then your 75 D 100 has, if that is going to matter. The late 70s "C & B: body 9 1/4 is the same width as your 76 D 100 and probably has the same bolt pattern, but likely has 2:76 gears, with or without a limited slip.
Can't offer any info after the Dakota went back to the 5 bolt wheels. The newer Dakotas may well have used the full sized truck axles, but I think those are 5 on 5" or 5 on 5 1/2" wheel bolt pattern.
Re: 1976 D series Question [Re: poorboy] #3134396
04/02/23 10:29 AM
04/02/23 10:29 AM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
The D100 info you seek is right here in the Moparts Archives......... Axle Widths
It stops at '74 but I can assure you its the same for '76 (2 wheel drive). The D100 rear axle is the same width as a C-body rear.
The drum to drum measurement is 64 3//8"
John
Re: 1976 D series Question [Re: SattyNoCar] #3135931
04/06/23 12:37 PM
04/06/23 12:37 PM
Bennett, Colorado
Bennett, Colorado
Thank you for the replies and the link Satilite73. Was right here under my nose and didn't find it. This is a 6 lug axle from the Dakota. And Poorboy. your note about the C-body rears is verified in the tech info link shared.
2012 Challenger SRT
69 Charger R/T
