Re: Small SUV hits tire [Re: not_a_charger] #3133240
03/29/23 11:01 AM
03/29/23 11:01 AM
central il.
second 70 Offline
second 70  Offline
central il.
Originally Posted by not_a_charger
Originally Posted by Rhinodart
That's what you get for driving a Killed In Action... tsk
Ignoring the fact that the people in the Kia survived this horrible accident that was caused by what kind of vehicle? laugh2
Can't blame GM. Only fair answer to that question would be modified.
Re: Small SUV hits tire [Re: second 70] #3133244
03/29/23 11:08 AM
03/29/23 11:08 AM
Puttin' on the foil in Charles...
not_a_charger Offline
Mr. Big Shot Moparts Moderator
I'm not blaming GM. I'm also not celebrating that the people in the Kia could've been killed.
Earning every penny of that moderator paycheck.
DBAP
Re: Small SUV hits tire [Re: not_a_charger] #3133301
03/29/23 01:41 PM
03/29/23 01:41 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
Screw it...I'm blaming GM. It makes me feel good.
Facts are stubborn things.
Re: Small SUV hits tire [Re: larrymopar360] #3133341
03/29/23 02:44 PM
03/29/23 02:44 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I think any and all wheel bearing failure is usually accompanied with miles and miles of some kind of "that's not normal" sound. That thing had probably been howling for months before it finally came apart.
68 Barracuda Formula S 340
Re: Small SUV hits tire [Re: Bad340fish] #3133380
03/29/23 04:14 PM
03/29/23 04:14 PM
Rocky Hill, Ct
Roadcuda Offline
Roadcuda  Offline
Rocky Hill, Ct
A friend suggested it might have been a bad wheel spacer. Those tires do look like they were sitting wider then factory wheels would sit so maybe a defective after market wheel that failed?
69 Fury convertible
69 Roadrunner
75 Scamp
14 Ram 1500
18 Jeep Cherokee
www.69roadrunner.net www.plymouthbulletin.com
Re: Small SUV hits tire [Re: Roadcuda] #3133424
03/29/23 05:45 PM
03/29/23 05:45 PM
It looks like the rotor is still attached to the wheel. I think that suggests bearing failure.
DBAP
Re: Small SUV hits tire [Re: not_a_charger] #3133426
03/29/23 06:01 PM
03/29/23 06:01 PM
Super Spudsville
Mr PotatoHead Offline
Half Baked
Half Baked
Super Spudsville
The rotor is clearly on the wheel. Im sure it will be looked at under a microscope due to the extreme accident.
Yea, were sorta joking about it. But its after the fact and we did not cause it.
The factory big tire chevy trucks do not place the wheel out that far as on this truck. Owner modified, tire shop modified?
That truck would be illegal with the tires sticking out like that in my state.
Screenshot 2023-03-29 at 15-59-01 2022 Silverado ZR2 Is Chevy's Gnarliest Off-Road Pickup Truck.pngScreenshot 2023-03-29 at 16-03-27 Small SUV hits tire.png
STOP POTATO HATE!
Re: Small SUV hits tire [Re: Mr PotatoHead] #3133479
03/29/23 08:20 PM
03/29/23 08:20 PM
AndyF Offline
AndyF  Offline
Truck is probably illegal in most states since the tires stick out so much. Either lots of offset on the wheels or big wheel spacers. If I was investigating the accident I'd start with the assumption that the aftermarket parts caused the failure which caused the accident and then work from there. Seems the most likely explanation to me.
Re: Small SUV hits tire [Re: bigdad] #3133487
03/29/23 08:46 PM
03/29/23 08:46 PM
IMGTX Offline
IMGTX  Offline
It appears the side impact airbags were already deployed while it was in the air.
I have to wonder did the impact trigger it or did the car figure out it was off the ground and expected a rollover?
I don't work on the airbag systems but I didn't expect them sides to deploy from what was effectively a front end collision when they deployed.
I can say some of the new stuff is pretty tuff, easy to total, but the structure is tough. I broke 1/4" drill bits installing a left hand gas pedal in a Subaru Just drilling trough the floor pan. Not the structure just the approx 18 gauge (less than 1/16") pan. Crazy hard and took forever to drill.
Re: Small SUV hits tire [Re: IMGTX] #3133497
03/29/23 09:17 PM
03/29/23 09:17 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I would suspect that as soon as the KIA had contact with the tire and went airborne, the air bag sensors detected the the vehicle was out of what would be considered a "normal plain" and would go off. I'm sure that once the frontal bags deployed (impact with the tire) all the other air bag sensors were activated to determine if the vehicle had left the "normal" plane. I doubt nose straight up would have been considered as "normal", and for sure, nose down, rear up, and then upside down wasn't normal.
As for the roof structure, I question the model year for the roof reinforcement. Somewhere around 75 I bought a 72 2 door Plymouth Satellite. Within a few months of that purchase I saw a string of 3 or 5 71 & 72 Satellites or Road Runners that had been put on their roofs. I went and looked at every one of them. I know at least two just sort of flopped over on the roof from going into a ditch. All of them had the top windshield header smashed down against the steering wheel. I remember having a less then favorable opinion of the roof structure of that 2 door body style. Fortunately, my car never had that experience.
Re: Small SUV hits tire [Re: poorboy] #3133776
03/30/23 11:44 PM
03/30/23 11:44 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I drive that stretch of the 118 fwy at DeSoto exit about once a week.
Those trucks with over sized heavy rims kill braking performance and longevity too.
IMHO when it's that jacked up in the air, they should require mud flaps in the back to avoid throwing rocks that damage other vehicles.
Re: Small SUV hits tire [Re: autoxcuda] #3133788
03/31/23 01:15 AM
03/31/23 01:15 AM
I wouldn't, and don't , call that little econ box a SUV tsk whistling
Re: Small SUV hits tire [Re: Cab_Burge] #3133802
03/31/23 07:30 AM
03/31/23 07:30 AM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
Are you questioning bigdad? tsk shake_head
John
Re: Small SUV hits tire [Re: SattyNoCar] #3133876
03/31/23 12:10 PM
03/31/23 12:10 PM
No questions, just the facts, Jack up scope grin
Re: Small SUV hits tire [Re: Cab_Burge] #3133879
03/31/23 12:15 PM
03/31/23 12:15 PM
Super Spudsville
Half Baked
Half Baked
Super Spudsville
Cab it is a SUV....... STUPID USELESS VEHICLE=SUV
STOP POTATO HATE!
Re: Small SUV hits tire [Re: Mr PotatoHead] #3133894
03/31/23 12:51 PM
03/31/23 12:51 PM
moparx Offline
moparx  Offline
HAHAHAHAHA !! i have called them that as well for a long time as well ! haha
beer
Re: Small SUV hits tire [Re: moparx] #3133968
03/31/23 03:50 PM
03/31/23 03:50 PM
Detroit area
6PAX Online content
6PAX  Online Content
Detroit area
Good thing that wasn't a convertible.
Re: Small SUV hits tire [Re: IMGTX] #3133974
03/31/23 04:08 PM
03/31/23 04:08 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Re: Small SUV hits tire [Re: IMGTX] #3133988
03/31/23 04:58 PM
03/31/23 04:58 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
All these things are equipped with lateral sensors, yaw sensors as well as impact sensors. ALL the modules in that car were well aware it was off it's intended path(drastically) and therefor deployed the bags....as it should!
