5 pin ecu with single ballast on repop harness?? #3133709
03/30/23 06:22 PM
03/30/23 06:22 PM
BC Canada
O
ogopogo Offline OP
ogopogo  Offline OP
O
BC Canada
I have and hope to use a new repop( purchased 10 or more years ago) 71 340 4 speed cuda engine harness,trying to figure out why it is wired for a 2 pin ballast and a 5 pin ecu...how can i make this work? was it made wrong?
Re: 5 pin ecu with single ballast on repop harness?? [Re: ogopogo] #3133712
03/30/23 06:35 PM
03/30/23 06:35 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Unless you have an original (not a new one) 5 pin ECU don't worry about it the new ECU's do not heed the 5th pin. You can install the dual ballast for looks, but it is unneeded.
Re: 5 pin ecu with single ballast on repop harness?? [Re: Sniper] #3133731
03/30/23 08:04 PM
03/30/23 08:04 PM
BC Canada
O
ogopogo Offline OP
ogopogo  Offline OP
O
BC Canada
thanks Sniper,upon closer examination its a new repop points harness that came with a project car I bought,and that guy converted it to electronic,incorrectly.......fixed now :-)
Re: 5 pin ecu with single ballast on repop harness?? [Re: ogopogo] #3133976
03/31/23 04:23 PM
03/31/23 04:23 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
All ECU plugs are ready for 5 pins, no one for 4 pins. If the harness is set for single ballast, then the unused pin wire is arriving nowhere down the harness.
Now, if the harness is set up for dual ballast, then the 5th pin wire (green with red trace) is arriving to the secondary resistor section. Which still if using a dual ballast with a 4 pins ECU, it won’t be any kind of load (althought still voltage present) on ballast secondary resistor or related wiring. Just with 5 pins ECU it will be in real use with some load.
