It's the motorguard M-60... Once the original filter is used up you can use a roll of toilet paper...
M-60 linkI use one for painting, it works better than the conventional filters...
Short of an actual drier I have used the motorguard filters since 1983 or or so.
1. I run a large Dia. high pressure hose and fittings to isolate the the compressor from the 1" ? copper line.
2. The hose is then attached to a 1/2"NPT or larger coalescing filter right before the copper line.
3. At each drop there is another coalescing filter sized on intended use.
4. At the blast cabinet I place a larger coalescing fiter which feeds directly into the Motor Guard filter. The outlet the goes directly to the cabinet which has another coalescing filter.
5. My main drop sometimes used for painting and a plasma cutter has a 3/4"? NPT coalescing filter into a DeVilbiss CAMAIR CT30 desiccant dryer
I have NEVER had a water problem with the Motoguard M-60's when plumbed as above. Even at the blast cabinet which eats a lot of air. I do put a 1/8" petcock in the bottom of them and drain all after each use.
If you're running a long hose, a small inline filter should still be used when painting as a precautionary measure. They sell a desicant filled hose but I've never used one
Due to downsizing I do have one used and 1or 2 new M-60's and extra filters. Also might sell the Ct-30. if anyone is interested PM me the ct-30 is due for a new bag
