Re: How do YOU tell if your damper is still good?
[Re: Hot 340]
#3132426
03/26/23 12:00 PM
03/26/23 12:00 PM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
I would replace a stock dampner if:
1. any wobble 2. Outer ring slipped and timing mark is off ( you can confirm this) 3. Rubber is cracked or disintegrating 4. You race you car and rev over 6-6500 rpm regularly. ( in this case, I would also replace stock steel pulley with cnc alum). Mine exploded at top end of track on a run. I got lucky even though I drove over it with slick. )
[Re: Hot 340]
#3132428
03/26/23 12:03 PM
03/26/23 12:03 PM
Posts: 31,049 Oregon
AndyF
Besides just buying an ATI, how do you tell if it needs rebuilt or not doing its job. I'm asking from a technical perspective, not a price point perspective. Internal clues to look for ect? ATI recommends regular rebuilds on their dampers. Pro guys rebuild every season, bracket guys might go a few seasons between rebuilds. NASCAR rebuilds after every race. It all depends on how serious you are and how much power you're making.
[Re: Hot 340]
#3132698
03/27/23 11:42 AM
03/27/23 11:42 AM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
Besides just buying an ATI, how do you tell if it needs rebuilt or not doing its job. I'm asking from a technical perspective, not a price point perspective. Internal clues to look for ect? what damper do you have ?
[Re: Hot 340]
#3132746
03/27/23 02:02 PM
03/27/23 02:02 PM
Posts: 4,209 New York
polyspheric
New York
The damper’s rubber ring will naturally decay with age, mileage, exposure to hot chemicals, vibration, ozone, and ultra-violet light, and become unsuitable for even a stock engine, let alone high performance or racing use. Visible signs of damage and potential failure include: » the rubber is partially missing » the rubber is discolored gray or “chalky” » the rubber has surface cracking » the rubber has been partially extruded » the damper rim is dented or bent » the damper is loose on its hub or on the crankshaft nose » the damper rim has excessive run-out (“wobble”) » a “squeaking” noise that defies detection
Boffin Emeritus
[Re: Neil]
#3132777
03/27/23 03:48 PM
03/27/23 03:48 PM
Posts: 4,684 Wichita
GY3
Wichita
I wait until they start banging and scraping against the timing cover! I've had both an OEM and 440 Source go bad in the last few years. Both showed no signs of failure before coming apart.
[Re: polyspheric]
#3132938
03/28/23 09:22 AM
03/28/23 09:22 AM
JohnRR
U.S.S.A.
The damper’s rubber ring will naturally decay with age, mileage, exposure to hot chemicals, vibration, ozone, and ultra-violet light, and become unsuitable for even a stock engine, let alone high performance or racing use. Visible signs of damage and potential failure include: » the rubber is partially missing » the rubber is discolored gray or “chalky” » the rubber has surface cracking » the rubber has been partially extruded » the damper rim is dented or bent » the damper is loose on its hub or on the crankshaft nose » the damper rim has excessive run-out (“wobble”) » a “squeaking” noise that defies detection all good stuff right here .
[Re: JohnRR]
#3135905
04/06/23 11:34 AM
04/06/23 11:34 AM
Posts: 3,395 Pa
Hot 340
Pa
Sorry for the late reply..been busy. Thanks for the input, I had a sfi powerbond on it and just wanted to see if there were clues in the rotating assembly to look for while I had it apart to see if it was doing its job. I just decided to go with an ATI...
