Re: Do all Mustangs come standard with Autocrash installed? [Re: Sniper] #3128445
03/11/23 02:37 PM
03/11/23 02:37 PM
moparx Offline
moparx  Offline
Originally Posted by Sniper
Originally Posted by 19swinger70
Serious question:
What is it about the Mustangs that make them suddenly turn like that under hard acceleration? It seems like ALL of the Mustang crash videos have a handling scenario like that. Since this was on a track, I am assuming he didnt hit an oil-down or water spot.
If you watch closely you will see something come out the bottom and bounce back towards the starting line. What it is, I do not know.
possibly clipping the 60ft timer ? shruggy
it usually boils down to a [semi ?] high performance car and a low performance driver.
i wonder if unhooking the front or rear sway bar would help keep these cars from the "left turn Clyde........" syndrome ?
beer
Re: Do all Mustangs come standard with Autocrash installed? [Re: moparx] #3131327
03/22/23 07:32 AM
03/22/23 07:32 AM
Southern Maryland
klunick Offline
klunick  Offline
Southern Maryland
Have an 06 GT stick shift. I've heard it called the mustang curse. Something to do with the wheelbase is the best guess I have heard. All I know is drive very carefully if you go through water or are in the rain. I've had the car take off 2X since I've owned it starting in 2015. Raced a lot and this was all on the street after going through a puddle. Hit second gear and off to the left I went. Best I could do was countersteer and get off the gas. Happened extremely fast.
67 Barracuda FB 69 Superbee "Southern Maryland: If you want a good looking woman, you had better bring her with you"
Re: Do all Mustangs come standard with Autocrash installed? [Re: klunick] #3131339
03/22/23 08:59 AM
03/22/23 08:59 AM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
They come by it naturally. Especially leaving car shows...
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: Do all Mustangs come standard with Autocrash installed? [Re: wingman] #3131369
03/22/23 10:25 AM
03/22/23 10:25 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
I never had this happen on my Mustang, 96. But it was just a v6 model, so low performance enough to match the skills of the driver? lol
Re: Do all Mustangs come standard with Autocrash installed? [Re: Sniper] #3131578
03/22/23 10:04 PM
03/22/23 10:04 PM
Southern Maryland
klunick Offline
klunick  Offline
Southern Maryland
One thing I have noticed is that modern traction control does things that actively work against your input.
Been many a time the rear has gotten loose in slippery weather, I steering into it, traction control kicks in and the vehicle starts to get out of line big time. The only solution there is to get out of it, or lobotomize the traction control.
On Mustang GTs and above you can turn off traction control
Re: Do all Mustangs come standard with Autocrash installed? [Re: klunick] #3131611
03/23/23 08:34 AM
03/23/23 08:34 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Yes, cause you have all the time in the world to do that when it happens.
Re: Do all Mustangs come standard with Autocrash installed? [Re: Sniper] #3132222
03/25/23 03:52 PM
03/25/23 03:52 PM
Southern Maryland
klunick Offline
klunick  Offline
Southern Maryland
He was at the drag strip
Re: Do all Mustangs come standard with Autocrash installed? [Re: klunick] #3132250
03/25/23 05:35 PM
03/25/23 05:35 PM
Wisconsin
W
wjb123 Offline
wjb123  Offline
W
Wisconsin
I felt pretty bad for this guy. Must have been a horrific experience. Still got a little laugh out of the wipers going off just after the air bag deployed. You want to see clearly what kind of mess you're in!
Re: Do all Mustangs come standard with Autocrash installed? [Re: wjb123] #3132285
03/25/23 07:02 PM
03/25/23 07:02 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
You would think the people at track have launched the car hard many times before going to track and know the feel of the car, rwd, etc. and know how to recover from oversteer. The suspension doesn't appear stock, but I might be wrong. It seemed to hook up well. Front end didn't lift much but rear didn't squat either.
Edit: It did look like it was at shift point.
Facts are stubborn things.
Re: Do all Mustangs come standard with Autocrash installed? [Re: larrymopar360] #3132303
03/25/23 07:48 PM
03/25/23 07:48 PM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
if you want to launch your s197 mustang straight at the track install one of these rear roll bars. .
https://www.bmrsuspension.com/?page=products&productid=792&superpro=0
i have one on my car. paid $400 for it in 2008. only use it at the track. .
run 1.4 60ft times with mid to low 10's @ 140+ mph. launches straight every time when i launch at 4.5 K rpm on bias slicks. if i could shift better probably hit 9's
perception is 90% of reality
Re: Do all Mustangs come standard with Autocrash installed? [Re: Mr T2U] #3132350
03/25/23 11:24 PM
03/25/23 11:24 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
It sure looked like the car whipped the driver's ability, but its also a possibility something broke at the shift. After the crash, it could be pretty to look at the screwed up car to find what got broke during the crash, or what might have broke causing the crash.
For that driver, the unfortunate thing is that so many published Mustang videos that ended in a crash was mostly caused by the driver's inability to handle the car's output.
Re: Do all Mustangs come standard with Autocrash installed? [Re: klunick] #3132373
03/26/23 08:25 AM
03/26/23 08:25 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Apparently you race in slippery weather? I wasn't talking about this particular crash., or mudstains in particular but rather modern cars with "traction control" in normal daily driving, which a lot of mudstain wipeouts appear to happen as well.
