Re: Race engine oil viscosity
[Re: Biginchmopar]
#3131760
03/23/23 06:17 PM
03/23/23 06:17 PM
Posts: 2,411 Weatherford, Texas
RapidusMaximus
Weatherford, Texas
Goodness gracious that’s a beautiful car Are you on methanol or gas?
1968 Plymouth GTX 1974 Dodge P/U Long Bed Stepside 318 2019 Ram 2500 6.4, auto, 4WD
[Re: 71Demon528]
#3132625
03/27/23 09:16 AM
03/27/23 09:16 AM
Posts: 2,504 PA
moparacer
PA
https://drivenracingoil.com/rt-5996-catalog.htmlDownload the catalog and find their chart on viscosity recommendations. I attached a photo as well. The section on viscosity recommendation also explains about running alcohol and how to choose a viscosity right for your engine. I am not anywhere near as smart as they are but the best way to deal with fuel dilution on a E85 or Alky setup is #1 work on your tune so it doesn't milk the oil, #2 run the proper crankcase evacuation AKA a vac pump so what moisture is created is removed and #3 run your engine hot enough to help with evaporation of the moisture so the pump can remove it. Nothing good ever comes from diluted oil.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: moparacer]
#3133491
03/29/23 09:03 PM
03/29/23 09:03 PM
Posts: 4,243 Canada
Kam*Kuda
Canada
I have been using 20W 50 and I believe that is why I am wearing down my bronze gear so quickly
I plan on switching to 10w30
1970 Barracuda Convertible 1968 Satellite Street Strip car 1654.5 Mustang 1955 Land Rover
