Page 2 of 3 1 2 3
Re: Race engine oil viscosity [Re: madscientist] #3130932
03/20/23 07:40 PM
03/20/23 07:40 PM
Cab_Burge Online work
Cab_Burge  Online Work
Valve spring pressures and idle RPM can have a lot to do with how soon and how hot the oil temps will get, especially when warming the motors up on a engine dyno shruggy
Re: Race engine oil viscosity [Re: RapidusMaximus] #3130933
03/20/23 07:42 PM
03/20/23 07:42 PM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
I broke mine in on 20w-50 brad penn but oil pressure was pretty high.
1150 idle, 49psi
2000rpm 70psi
7600rpm 78psi
(I think it was just going through the bypass pretty early)
I've since switched to Royal Purple XPR 5w-30 and will dyno again soon.
Re: Race engine oil viscosity [Re: polyspheric] #3130940
03/20/23 08:20 PM
03/20/23 08:20 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Originally Posted by polyspheric
A joke: the 1st number in a multi-viscosity, or the only number in single viscosity is the time in seconds it takes when cranking a cold engine for oil pressure to reach the last connecting rod.
20W50: 20 seconds.
Not even close.
Doug
Re: Race engine oil viscosity [Re: AndyF] #3130991
03/21/23 12:01 AM
03/21/23 12:01 AM
Deep DEEP SOUTH
LAD 524 Offline
LAD 524  Offline
Deep DEEP SOUTH
Originally Posted by AndyF
I ran an oil temp sensor in my Duster. It takes a long time for oil to heat up. Usually takes about 10 miles of driving before oil is up to temp. Oil doesn't get warm in the pits or driving to the staging lanes.
Same here, it takes time for oil temp to warm up. I see mostly between 180-220 temps on the street depending on ambient/engine temp and load and it takes a little while to get it there.
Thing is...I am told the zinc/phos/wear additives are designed to do their thing when the oil is at operating temp.
Or in other words they are pretty much along for the ride till that time.
Re: Race engine oil viscosity [Re: LAD 524] #3131017
03/21/23 08:16 AM
03/21/23 08:16 AM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
If your bearing clearances and sizes support it, lighter weight oil is free horsepower.
I have run into issues on OEM stuff where if the journal area is marginal for the load on the bearings, that heavier viscosity oil when at temp is needed to keep the bottom end safe. That's one of the reasons why a bunch of new cars require oils with a wide spread, like 0w40 or 5w50.
I run 15w50 Mobil 1 in my motor because it's cheap at Wal Mart and has enough zinc for flat tappet cams. I'd prefer a 5 or 10w40 for cold starts since mine is mostly a street car, but my wallet prefers the 15w50. lol
Re: Race engine oil viscosity [Re: Blusmbl] #3131020
03/21/23 08:25 AM
03/21/23 08:25 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Mine only shows oil temp before the run on back to back runs. But it will make it to 150 at the end of just about any run. My clearances are out of the normal range for thicker oils either. With some warm up it'll run its number right off the bat. Very important on mornings without a time trial.
Doug
Re: Race engine oil viscosity [Re: dvw] #3131045
03/21/23 10:21 AM
03/21/23 10:21 AM
PA
moparacer Offline
moparacer  Offline
PA
I warm mine up to 150 before I make a pass. I have a gas primer so I can build heat quickly without wasting alky. Last year double entered running the guts out of it sometimes the oil would get close to 200. I run an engine oil cooler since I have a tall fill.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Race engine oil viscosity [Re: dvw] #3131061
03/21/23 11:10 AM
03/21/23 11:10 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Perhaps you didn't notice the first word, "joke".
What does "not even close" mean to humor?
Boffin Emeritus
Re: Race engine oil viscosity [Re: RapidusMaximus] #3131063
03/21/23 11:12 AM
03/21/23 11:12 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Oil temperature tracks load, not water temperature or minutes of operation.
Power: cold water & hot oil.
Boffin Emeritus
Re: Race engine oil viscosity [Re: polyspheric] #3131080
03/21/23 12:03 PM
03/21/23 12:03 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
We find generally an oils viscosity is pretty stable from 215-250. I wouldn't have any issue starting a run at 210 or so *f using ANY type of oil. Synthetics tolerate 40 or so degrees more before critically degrading, conventional oils will coke about 275F
Re: Race engine oil viscosity [Re: polyspheric] #3131092
03/21/23 12:28 PM
03/21/23 12:28 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
This.
From Stockers to Pro Stock. Fastest way is pre-heat the oil. Come out of the lanes cold. You have to tune for that. We're using gauges to measure down to 60 degrees water temp.
Brackets, .90, dial in consistency - warm it up. Keep the temp swing from first round to the final to a minimum.
10w30 is for bracket cars. Class cars go thinner. Haven't had a quart of 20w50 in my shop for decades. Stopped using dino oil too. Made a difference
Eliminating internal leaks and unnecessary oil flying everywhere except to the crank is part of doing that. Some builders tighten clearances in the bottom end as well.
Better oils than what we had years ago also helps
Re: Race engine oil viscosity [Re: polyspheric] #3131163
03/21/23 03:51 PM
03/21/23 03:51 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Nope missed it completely. That response did sound strange coming from you. Must have read it after the bar . On vacation in Key West, lol
Doug
Re: Race engine oil viscosity [Re: dvw] #3131168
03/21/23 04:30 PM
03/21/23 04:30 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
Am I the only one who has an oil pan heater? Roll car out of trailer, plug in heater, wait 30 mins, start car when oil gets to 160.
Joe
Without Data, you’re just another guy with an opinion.
Re: Race engine oil viscosity [Re: sr4440] #3131179
03/21/23 05:23 PM
03/21/23 05:23 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Joe
Nope. We have cars with heaters on the pan, accusump and trans pan. And I'm gonna put one on the rear when I get a chance.
Cheap ET.
Re: Race engine oil viscosity [Re: CMcAllister] #3131439
03/22/23 01:17 PM
03/22/23 01:17 PM
moparx Offline
moparx  Offline
when you say the oils are better today than back then, does that mean the pennzoil 60wt racing oil in the cardboard cans i have is not to be used ? biggrin
beer
Re: Race engine oil viscosity [Re: moparx] #3131441
03/22/23 01:19 PM
03/22/23 01:19 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
FWIW in the Vette we run 0 weight oil...Bearings have been in the car for the last 5 years. In my bracket junk we use 5w20
Re: Race engine oil viscosity [Re: Al_Alguire] #3131444
03/22/23 01:32 PM
03/22/23 01:32 PM
moparx Offline
moparx  Offline
for whatever this is worth, my brother inherited a buick from his mother-in-law years ago when she passed.
he drove it a bunch of miles using 10-30, changed oil and filter religiously, and it ran like a top.
after it topped 130k or so, he figured it was getting a little worn, so he put in the same brand oil he had been using before, but this time, 10-40.
upon fire up, it had lifter noise it never had before. as there was nothing on the dash except an idiot light, he had no idea what the pressure was.
he drove it for a week or two, and it still had the noise.
he dumped the 10-40 and went back to 10-30, and the noise was gone ! lesson learned. he used 10-30 until he wore the car out, and no more noise.
beer
Re: Race engine oil viscosity [Re: moparx] #3131458
03/22/23 02:29 PM
03/22/23 02:29 PM
ohio
dragon Offline
dragon  Offline
ohio
Does anyone run a oil pan surface heater with a diaper???
Re: Race engine oil viscosity [Re: dragon] #3131474
03/22/23 03:19 PM
03/22/23 03:19 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I just use 10W30 conventional in everything except my Diesel. I use 15W40 Rotella.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Race engine oil viscosity [Re: dragon] #3131485
03/22/23 04:00 PM
03/22/23 04:00 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I thought about it. I have one. But didn't know how it would do with the padding.
Doug
Page 2 of 3 1 2 3
