11" drum rear backing plates #3130912
03/20/23 05:29 PM
03/20/23 05:29 PM
Mattituck NY.
FJ6AAR Offline OP
FJ6AAR  Offline OP
Mattituck NY.
Hi all, I am wondering if anybody can tell me if these are the early - up to 1970 or later, 1971 and up backing plates for the rear brakes - 11". I need to buy the brake strut lever and I see there are different ones for the early and the later backing plates with the split coming between 1970 and 1971. I sent the photos to a well respected Ebay vendor who sells the levers but he could not 100% tell by the photos. I just want to order the correct parts the first time and be done. Any help is appreciated. Thanks, Rob
1970 Hemi 'Cuda hard top clone
1971 Hemi 'Cuda Convertible clone
Re: 11" drum rear backing plates [Re: FJ6AAR] #3130918
03/20/23 06:56 PM
03/20/23 06:56 PM
Mattituck NY.
FJ6AAR Offline OP
FJ6AAR  Offline OP
Mattituck NY.
It looks to me after comparing photos on the internet and Ebay, the difference I see is where I circled. Others appear to have more meat in that area. So, it looks like these are later, maybe much later than I thought?
Re: 11" drum rear backing plates [Re: FJ6AAR] #3130920
03/20/23 07:11 PM
03/20/23 07:11 PM
I think there are three different 11 inch backing plates and brake drums depending on the width of the shoes, 11.0x2.0, 11x2.5 and finally 11x3.0. scope Maybe not but I'm sure I've seen all three sizes, mainly on C bodies, maybe on some B body with the H.D. brake options chosen when it was built confused
Re: 11" drum rear backing plates [Re: Cab_Burge] #3130925
03/20/23 07:29 PM
03/20/23 07:29 PM
BDW Offline
BDW  Offline
I think the earlier parts were left and right, the later plates were universal and have 2 holes for the emergency cable
Re: 11" drum rear backing plates [Re: BDW] #3130935
03/20/23 07:44 PM
03/20/23 07:44 PM
Mattituck NY.
FJ6AAR Offline OP
FJ6AAR  Offline OP
Mattituck NY.
Thank you for the replies. Check out these two Ebay auctions - this is what is confusing me. One is up to 1970 and the other starts at 1971. I see the 1971 to 1975 is curled but not sure why?
Links:
1965 to 1970: https://www.ebay.com/itm/234795457116
1971 to 1975: https://www.ebay.com/itm/334641818073
Re: 11" drum rear backing plates [Re: FJ6AAR] #3130943
03/20/23 08:33 PM
03/20/23 08:33 PM
IMGTX Offline
IMGTX  Offline
I do not think they are twisted I think the support rib has the parts laying at an odd angle.
This is the rib on the 71 and later bar. I think the only difference in the two is the rib was not here on the 70 and older bar.
I think the bars are interchangeable as long as the rib clears the wheel cylinder.
Re: 11" drum rear backing plates [Re: IMGTX] #3130945
03/20/23 08:45 PM
03/20/23 08:45 PM
Mattituck NY.
FJ6AAR Offline OP
FJ6AAR  Offline OP
Mattituck NY.
Thank You, if I do buy the ones you pictured and if they do not fit because of the rib, it can be removed.
