Stick shift guys #3130143
03/17/23 02:07 PM
03/17/23 02:07 PM
South Park, Pa.
68LAR Offline OP
68LAR  Offline OP
South Park, Pa.
What is the cut off for weight to determine wither to use an aluminum of a steel flywheel? My car with me in it and a half tank of gas weighs in at 3926#. I have run both types of flywheels. The difference in ET and MPH with my set up is minimal. My car is mostly street driven. Street manners with the steel wheel seems better. The aluminum wheel weighs in at around 20# . The steel wheels is around 33#'s.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: Stick shift guys [Re: 68LAR] #3130155
03/17/23 02:37 PM
03/17/23 02:37 PM
I think it is up to you on which one you like, especially on a street and strip car twocents
I did a bunch of testing on flywheel diameter, clutches and pressure plates on my old 1970 Cuda Hemi 4 speed car, started off with with the stock 1968 170 tooth flywheel with the 11.0 inch clutch( I think weighed 40 lbs. switch to a 140 tooth flywheel with the 11.0 inch clucth which weighed a little less but I can't remember exactly how much now whiney
Next was a 130 tooth steel with a 10.95 clutch Borg and Beck style and later tried a Long Style 10.95 clutch, the last swap was to a 18 to 20 lbs. 130 tooth Aluminum flywheel with one of the 10.95 clutches. The car would spin the tires with all the steel flywheels and bog with the aluminum leaving at WOT on all of them shruggy
I fnally weigh the front and rear axle weigts and quit racing it after that, it had 2180 lbs. on the front tires and 1260 lbs. on the rear tires without me in it racing on a 9 inch wide slick shock puke: down:
Re: Stick shift guys [Re: Cab_Burge] #3130199
03/17/23 06:05 PM
03/17/23 06:05 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Sounds like you need to listen to Cale Aronson the the Clutch Burners podcast.
https://youtu.be/oLgQMFNkKCE
Lots of good info concerning clutch and flywheel weight.
69 GTX 68 Road Runner
Re: Stick shift guys [Re: 68LAR] #3130201
03/17/23 06:26 PM
03/17/23 06:26 PM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
I think not just race weight but SLR would be a consideration.
Re: Stick shift guys [Re: JERICOGTX] #3130226
03/17/23 09:00 PM
03/17/23 09:00 PM
South Park, Pa.
68LAR Offline OP
68LAR  Offline OP
South Park, Pa.
. Good info here. Thanks. Probably leave the steel wheel in.
Re: Stick shift guys [Re: 68LAR] #3130250
03/17/23 11:48 PM
03/17/23 11:48 PM
Washington
W
weedburner Offline
weedburner  Offline
W
Washington
There's a section on flywheel weight in a drag race scenario here... Clutch Tuning Basics
Grant
Re: Stick shift guys [Re: INTMD8] #3130255
03/18/23 01:00 AM
03/18/23 01:00 AM
iagree My Cuda with a 4.10 rear gear and 28.0 tal slicks would bog the motor at WOT on the starting line, work
I switch rear gears to 4.89 and went back to spinning the tires so I put some 29x9x15 slick on it and switch the rear gears to 5.13 to make it RPM through the lights realcrazy
That was back in 1974 to 1976, no internet and I was a learning rookie making mistakes testing and racing at the same time realcrazy
Once I weighed that cars front and rear weight I took it apart and sold it as a street car and bought back my old 1963 415 HP M.W. car and started winning bracket races and having fun boogie
My message is if it ain't fun, why do it work scope up twocents
Re: Stick shift guys [Re: 68LAR] #3130426
03/18/23 08:46 PM
03/18/23 08:46 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I was discussing flywheels with a few of the UMTR guys about aluminum flywheels and one of the opinions had my interest. The idea was that even though the inertia is greater with a steel wheel the aluminum wheel recovers RPM quicker between gear changes. shruggy I have a new aluminum wheel that I intend to use if I put the old Hays Mark XII plate back in because that 12 bolt adjustable plate is freakin heavy.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Stick shift guys [Re: fourgearsavoy] #3130433
03/18/23 09:02 PM
03/18/23 09:02 PM
South Park, Pa.
68LAR Offline OP
68LAR  Offline OP
South Park, Pa.
Gus beer
Interesting. Steel gets you moving better, but aluminum recovers between shifts better
Re: Stick shift guys [Re: 68LAR] #3130441
03/18/23 10:04 PM
03/18/23 10:04 PM
Washington
madscientist Offline
Washington
Gus beer
Not always. There are ways to make the lighter flywheel combo get you going like a steel wheel.
I don’t argue about it any more because it’s not worth it. I run an aluminum wheel in everything that is going to see some track time.
Of course, if you don’t have a way to APPLY the clutch then the steel wheel is a bandaid to get the car moving. Clutch application is critical.
Re: Stick shift guys [Re: madscientist] #3130445
03/18/23 10:31 PM
03/18/23 10:31 PM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
Gus beer
Can you point us to the thread where you did agrue it ? fan
Re: Stick shift guys [Re: JohnRR] #3130458
03/18/23 11:25 PM
03/18/23 11:25 PM
I've help other stick shift racers. years ago, using a early A body 3.09 first gear tranny in a later A body case, taught us that the starting line ratio and. 3rd to 4 th. gear RPM drop can make a lot of difference in a drag only car, especially SB cars work
5.57 rear gear with a 3.09 1st gear in a 3000 lb. SB stick shift drag car keeps you pretty busy ( hammer) the first 300 to 500 ft. depending on the rear tire size boogie grin
Re: Stick shift guys [Re: weedburner] #3130616
03/19/23 05:19 PM
03/19/23 05:19 PM
South Park, Pa.
68LAR Offline OP
68LAR  Offline OP
South Park, Pa.
Grant
The part about launch rpm vs trap rpm is very interesting. I may reconsider my aluminum wheel.
Re: Stick shift guys [Re: 68LAR] #3130665
03/19/23 08:41 PM
03/19/23 08:41 PM
Washington
Washington
Grant
Yup. At least reconsider it.
