Re: 727 issues
[Re: FastmOp]
#3130367
03/18/23 04:08 PM
03/18/23 04:08 PM
Posts: 5,763 Hot Rod Ridge
FastmOp
Hot Rod Ridge
The left holes are different between the two cases.
Now I have some of my parts mixed up. Can I use the small block case parts and if so. What's the description of parts in the 1st accumulator on the left for the bottom case.
Re: 727 issues
[Re: FastmOp]
#3130399
03/18/23 05:28 PM
03/18/23 05:28 PM
Posts: 25,977 Rio Linda, CA
John_Kunkel
Rio Linda, CA
What's the description of parts in the 1st accumulator on the left for the bottom case. That's the kickdown servo with the piston at the bottom of the bore. The bore in the case will accept any assembly with the main difference being the pre-'71 setup with the piston that is pictured (preferred) or the '71-later controlled-load servo with the larger diameter plunger. Pre-'71 is the top pic, controlled-load is bottom pic.
Re: 727 issues
[Re: FastmOp]
#3131554
03/22/23 08:56 PM
03/22/23 08:56 PM
Posts: 3,099 Michigan
A727Tflite
Almost done with this. But it has way to much end play. Going to add a brass washer in a plant. What?
Re: 727 issues
[Re: FastmOp]
#3131658
03/23/23 11:55 AM
03/23/23 11:55 AM
Posts: 2,697 Renton Wa
topfueldart
Renton Wa
I have about.090 end play. I must have forgotten a brass wear plate or something lol. Planetary endplay is totally separate from unit endplay, how are you measuring?
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
Re: 727 issues
[Re: FastmOp]
#3131681
03/23/23 12:51 PM
03/23/23 12:51 PM
Posts: 75,092 A Banana Republic near you.
JohnRR
Almost done with this. But it has way to much end play. Going to add a brass washer in a plant. Looks like you put it into reverse at about 50mph ...
