1970= 71 hemi carb manual choke #3129976
03/16/23 07:51 PM
03/16/23 07:51 PM
MILFORD, MICHIGAN
MILFORD MOPARS Offline OP
MILFORD, MICHIGAN
any leads on some rare parts, 1970 71 carter afb 426 hemi
my primary throttle shaft has been cut.and needs replaced, 68 to 71 are the same
primary choke shaft was robbed
probably in the 70s .....
all of the fast idle and manual choke linkage is missing.
ii did reach out to harms already.
appreciate Any help
Re: 1970= 71 hemi carb manual choke [Re: MILFORD MOPARS] #3130269
03/18/23 07:59 AM
03/18/23 07:59 AM
VA
dragon slayer Offline
VA
I sent you a PM with my email address. I may be able to help.
