Page 7 of 7 1 2 3 4 5 6 7
Re: Strange rivets [Re: srt] #3129155
03/13/23 07:58 PM
03/13/23 07:58 PM
robertop Offline OP
robertop  Offline OP
Reply to srt: I don’ t think there were any emission controls in 1968. The car has no headrests and has the full set of shoulder and lap belts. I bought a ECS exhaust and the resonators and mufflers from Accurate, but the bends in the latter parts are not right for the exhaust, so I will install them later. The resonator hangers are still there and are original from the time I got the car. The k member is original, you have to explain what the trunk lip is, but the original gasket is still there. Lastly. The radiator support was damaged in an early accident andI when I bought another one, I realized it was a 68 type, not 69, and that’s what is in now.
Re: Strange rivets [Re: robertop] #3129174
03/13/23 09:18 PM
03/13/23 09:18 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
just an FYI, there most certainly were federally mandated emissions controls in 1968. Some states like Ca. were stricter that the Feds. Chrysler was able t get by using what they called a "Clean Air Package" avoiding things like smog pumps etc. well into the 70's
beer
Re: Strange rivets [Re: TJP] #3129281
03/14/23 10:39 AM
03/14/23 10:39 AM
robertop Offline OP
robertop  Offline OP
You are right, TIP, apparently in Ca. you could not get chrome exhaust tips for 69, or so I have been told; call those “emission controls”, if you will. For Ga. it was different, but you are correct.
Re: Strange rivets [Re: robertop] #3129283
03/14/23 10:41 AM
03/14/23 10:41 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
I thought the turn downs were a noise control thing, not emissions
I want my fair share
Re: Strange rivets [Re: SomeCarGuy] #3129286
03/14/23 10:45 AM
03/14/23 10:45 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Exactly, along with a dual snorkel "silenced" air filter cover on most vehicles.
Re: Strange rivets [Re: robertop] #3129326
03/14/23 12:40 PM
03/14/23 12:40 PM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
idk how widespread (vs only CAP) the vac advance on 68's is apparent on CA Hemis (and other?) chrysler hp cars.
Big write-up here /click
It was common the factory stuff was torn off and lost. In the mid and late1980's anyone obtaining a smog certificate transferring a so equipped car had a kit installed that basically plugged the dist vac port and the mechanical advance had to be relied upon.
p.s. Fuel for thought. If the car was not pieced together and vin swap early on, seems it might not a have been intended a sellable/licensable car when it was reviewed by the press as it had no head-rests. THey became manditory Jan 1 '69.
Re: Strange rivets [Re: A12] #3129332
03/14/23 01:20 PM
03/14/23 01:20 PM
SomeCarGuy Offline
SomeCarGuy  Offline
What year were the ca cars sold like this? I thought 69, but I’ve seen something’s suggesting it was 1970. With the dual snorkel and the turndowns that is.
Re: Strange rivets [Re: SomeCarGuy] #3129353
03/14/23 02:21 PM
03/14/23 02:21 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
My '69 LA built and LA area (Norwalk, CA) originally sold GTX had a dual snorkel air cleaner cover and no exhaust tips. Sure it was '69 and then in 1970+ California EVAP required the snorkels have vacuum closures to minimize carburetor float bowl fumes from exiting out the air filter cover inlets (snorkels) and the closing hood scoops when the engine was turned off (no vacuum).
(I have since put an unsilenced air filter cover on the GTX and exhaust tips)
Re: Strange rivets [Re: A12] #3129363
03/14/23 02:59 PM
03/14/23 02:59 PM
SomeCarGuy Offline
SomeCarGuy  Offline
That’s the conclusion I came to with my 69. The exhaust tip hanger bolt holes look like nothing has ever been in them. It has an unsilenced cleaner now and I plan to out tips on. Just doesn’t look right without them.
Re: Strange rivets [Re: SomeCarGuy] #3129393
03/14/23 04:44 PM
03/14/23 04:44 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
A couple of my '69 RRs had no tips - CA cars - and one had the dual snorkel (AC car); the other (335hp) the air cleaner was missing when I bought it.
Both were Decor cars, being HTs. Both built in St Louis.
The '69 Decor RR I have now (SD car when new) has tips, but AG. Also from the St Louis plant.
All my '68 RRs I can recall or have now (CA cars except one from NV) had unsilenced air cleaners, and 1 Decor car had the tips, but it was originally from CO. Non-decor = no tips.
One of my '68 Chargers (R/T) had tips, the non-R/T 383/4bbl didn't until I added them, but oddly I don't recall tips or not on a couple of '69 Chargers I owned (project cars). Both CA cars.
Can't recall their air cleaners for certain, but I think my '68 383's was unsilenced. Both had AC.
All the above were/are original cars.
If a car was dealer-swapped from out of State into CA, it might have had 49-state items instead of the CA noise reduction items.
Funny thing is that I recall the LAPD Belvederes being pretty loud when the cops would charge down the street.
Re: Strange rivets [Re: TJP] #3129395
03/14/23 04:50 PM
03/14/23 04:50 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
PCV valve
Re: Strange rivets [Re: topside] #3129410
03/14/23 05:27 PM
03/14/23 05:27 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
I would bet a lot of California dealers both Plymouth and Dodge ordered by the truck load the unsilenced air cleaner covers and exhaust tips knowing a customer would want to buy and add those items. Like buying a motorcycle and adding a performance exhaust on day one or day two.
Re: Strange rivets [Re: A12] #3129468
03/14/23 08:07 PM
03/14/23 08:07 PM
A collage of whims
A collage of whims
A12 - I suppose that's possible. The cars I had with tips had no evidence of post-factory modification, though.
I'm thinking either the cars were re-directed, or dealer-traded, or the regulations were effective Jan 1st (as opposed to model year), as so other regs many were.
Most of my cars were bought from older "regular" folks, not performance-minded people.
No way to prove the air cleaners one way or the other, though everything seemed the same age - I've always avoided pieced-together cars.
Re: Strange rivets [Re: Sniper] #3129537
03/15/23 02:22 AM
03/15/23 02:22 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
PCV valve
It should have been termed a Smog Control, considering what smoke was emitted from crankcases before they were used.
Re: Strange rivets [Re: robertop] #3129538
03/15/23 02:32 AM
03/15/23 02:32 AM
Federal mandatory emissions requirements started in 1962 or maybe 1 or 2 years later with the PVC systems, 1966 Mopars had the little green vacuum advance emissions gadgets, several years later the fuel vapor return systems to the fuel tanks were installed by the factories, GM had the fresh air injection in either 1967 or 1968 puke
