Drill press #3129331
03/14/23 01:12 PM
03/14/23 01:12 PM
Keymar, MD
DusterKid Offline OP
Keymar, MD
Probably a long shot but I'm trying to find a part for my broken drill press. It's a Northern Industrial drill press Part Number 155301. I need item #68 on the parts drawing. It's referred to as the insert pulley. I've tried googling and ebay and such, but without an actual part number for the part, it's hard to find anything. Didn't know if someone that maybe repairs such items or has more knowledge would be able to help me locate one or not. If not I'll just have to go buy another drill press, but was trying to fix this one if I could.
Re: Drill press [Re: DusterKid] #3129340
03/14/23 01:45 PM
03/14/23 01:45 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Have you tried contacting Northern Tool? I
Re: Drill press [Re: John_Kunkel] #3129346
03/14/23 02:08 PM
03/14/23 02:08 PM
Keymar, MD
Keymar, MD
Yes, drill press is out of warranty, so they were no help.
Re: Drill press [Re: John_Kunkel] #3129349
03/14/23 02:09 PM
03/14/23 02:09 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I would start with John's suggestion. Might also try some other places like harbor freight, Grizzly, or other discount tool houses.
Most of the parts are interchangeable but that unit does look pretty old so that could be an issue. Any chance of repairing the existing one? beer
Re: Drill press [Re: John_Kunkel] #3129350
03/14/23 02:12 PM
03/14/23 02:12 PM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
While sitting here having lunch, I 'chatted' with Doug from there regarding this.
In a nutshell, he said its too old and no longer supported.
He showed me a newer model but the parts were totally different.
I think the part is mislabeled in the manual? What 68 is pointing to sure looks like a spindle, which 69 pointing to a pulley claims to be?
I tried to save the chat we had, as he suggested one place that might be able to help, but it hasn't shown up in my email (yet).
John
Re: Drill press [Re: DusterKid] #3129352
03/14/23 02:14 PM
03/14/23 02:14 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Is that shaft missing or worn? Have any machinist friends? Looks simple enough for any one that has a lathe and knows how to use it.
Re: Drill press [Re: GomangoCuda] #3129357
03/14/23 02:49 PM
03/14/23 02:49 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
iagree Pretty basic lathe job.
Re: Drill press [Re: DusterKid] #3129360
03/14/23 02:56 PM
03/14/23 02:56 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
I can't say whether they can help but you can check here.
https://littlemachineshop.com/
I've gotten parts for my Harbor Freight Mini Lathe from them.
Re: Drill press [Re: GomangoCuda] #3129362
03/14/23 02:58 PM
03/14/23 02:58 PM
Keymar, MD
Keymar, MD
It's broke in half where it changes in diameter from big to small. There's 2 bearings that mount on the bottom side with a spacer in between the bearings. The top part goes thru the top pulley. The center of the "insert pulley" is hollow for a square stock of the drill press shaft spindle.
Re: Drill press [Re: SNK-EYZ] #3129364
03/14/23 03:02 PM
03/14/23 03:02 PM
Keymar, MD
Keymar, MD
Thanks, I'll contact them to see if they can help me out.
Re: Drill press [Re: DusterKid] #3129369
03/14/23 03:29 PM
03/14/23 03:29 PM
5thAve Offline
5thAve  Offline
Do some random searching online for drill presses on google images and see if you can come up with another manufacturer or supplier. A lot of the time multiple companies sell the same drill press with their own name on it and you might be able to find someone who's more help getting parts if they still exist.
Re: Drill press [Re: 5thAve] #3129377
03/14/23 03:50 PM
03/14/23 03:50 PM
md
mopars4ever Online content
mopars4ever  Online Content
md
You can get a mini for $69.99 https://www.tractorsupply.com/tsc/product/black-bull-drill-press-with-laser-centering-guide-5-speed
I have the full size Black Bull 16 speed drill press. Used it only a few times, Wish I would have bought the mini. Takes up less space.
Re: Drill press [Re: mopars4ever] #3129390
03/14/23 04:30 PM
03/14/23 04:30 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Agreed that a guy with a lathe could knock that out fairly easily.
The question becomes, will he do it for less than the machine is worth.
Sad but true, much of this import equipment and tools are considered consumables. Use it 'till it breaks and get another.
I'm like you, I hate to throw otherwise good tools away. I'll usually spend the money to fix it, if it's a good tool otherwise.
Re: Drill press [Re: CMcAllister] #3129418
03/14/23 05:39 PM
03/14/23 05:39 PM
O
oldjonny Offline
Don't argue with me.
oldjonny  Offline
O
I suffer from the same problem. I just spent $60 to fix my old (like 43 years old) Craftsman 1HP air compressor. Probably should have just chucked it, but it did serve me well for a bunch of years. DeVilbiss actually made them back then, so maybe it was the right thing to do.
Never, ever argue with an IDIOT. They will drag you to their level and then beat you with their years of experience
Re: Drill press [Re: oldjonny] #3129423
03/14/23 05:54 PM
03/14/23 05:54 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I'd much rather repair something old that is quality. If you pitch and buy new, you have just gotten on the throw-away merry-go-round.
Re: Drill press [Re: 6PakBee] #3129453
03/14/23 07:20 PM
03/14/23 07:20 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Old Harbor Freight stuff was better quality then the new Harbor Freight stuff is.
Maybe you can find someone that has the same drill press that has something different broken on it and he will give you his at a cheap price.
That said, how much value does a $150 drill press have after 15 years of service? Did you get your $10 a year worth of use out of it?
What is going to break the week after you invest in having a new part machined?
Re: Drill press [Re: SattyNoCar] #3129487
03/14/23 09:30 PM
03/14/23 09:30 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Any chance he could research who the supplier was ? shruggy
Re: Drill press [Re: DusterKid] #3129488
03/14/23 09:32 PM
03/14/23 09:32 PM
IMGTX Offline
IMGTX  Offline
Is the hollow in the middle round or square to fit the drill press shaft spindle or is it round and the drill press shaft spindle connects to the pulley on top?
If the hollow is square then it may take a shop with a broach or something to make the square hole. (Not a machinist so I don't know what the options there are).
If that is the case it may be cheaper to have the two pieces welded together and machined down to fix it.
shruggy
If it seems like a decent tool then it would be worth fixing but I have seen some really bad crap being sold in the last couple decades.
Sadly it's kind of a crap shoot.
Re: Drill press [Re: mopars4ever] #3129520
03/15/23 12:07 AM
03/15/23 12:07 AM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
The comments on that drill press make it look like it's pretty hit and miss, it wouldn't be my first choice
Re: Drill press [Re: DusterKid] #3129539
03/15/23 02:43 AM
03/15/23 02:43 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Check ebay frequently. There's always people selling parts from older/rusted/damaged tools.
Don't just rely on what parts are listed, but what parts are listed for that Brand of press.
Somebody may have listed a different part for that press, but not that part.
Sometimes they may not list it, believing it's not a 'demand' item.
Contact them and see.
Also check sold/completed listings for that type press & inquire.
