Dana 60 Powerlock Clutch Pack #31286
09/25/06 07:17 PM
09/25/06 07:17 PM
maxwedgetwo Offline OP
Got a new Mopar Performance clutch pack rebuild kit today for a Dana 60.
The included instructions as well as any other tech info I can find calls for the clutchs to be installed in this sequence:
Side gear - flat disc - flat plate - dished disc - disc plate.
The new kit only contains dished plates and dished discs for all locations.
Has there been a change? Has anyone ran into this?
Maybe Doctor Diff or John Kunkle ????
"Hemi" The most feared 4 letter word in racing.
Re: Dana 60 Powerlock Clutch Pack [Re: maxwedgetwo] #31287
09/25/06 07:56 PM
09/25/06 07:56 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
New style Dana 60 power-lock clutch packs with fiber plates are assembled:
1. Clutch hub (starting point)
2. Flat plate with ears
3. Dished disc**
4. Flat plate with ears
5. Dished disc**
6. Flat plate with ears
**Assemble dished disc with ID contacting outer plates.
Drench clutch plates in straight friction modifier additive as you assemble them.
Torque case half bolts to 80 lbs. Use red loc-tite on threads.
Re: Dana 60 Powerlock Clutch Pack [Re: maxwedgetwo] #31288
09/25/06 08:03 PM
09/25/06 08:03 PM
Thanks Doctor DIff. You are the MAN.........
