Definitely different looking, Mopar had two different size and type of both solid and hydraulic lifters, 1966,(maybe 1967 and earlier) and earlier had 1/4 inch cups in them and two different cup heights, hydraulic lifter cup are higher.
1967 and later use 5/16 cups but the same on the cup heights being different.
The solid don't have any guts in them, the hydraulics lifters do
You can remove the retainer rings, snap rings and look inside to see if they are solid or hydraulic lifters
Let us know what you find
